Author Topic: How to tell if you have a bent solid front axle??  (Read 6526 times)
GM Man
  • Male Posts: 11
  • Member since Jun '09
« on: Jun 10, 2009, 05:38:26 PM »
So I picked up a 85 front axle this past weekend, and I have been reading that some members have bent their housings.  Where do these axles bend at on the long side, and is it very obvious?  I have looked over my axle and I cant find anything that looks like its bent..  Thanks!! :bowdown: :bowdown:
Just starting out, looking to buy a 90-95 4Runner...
87pickup
  • Turtle Points: 33
  • Male Posts: 719
  • Member since Jul '07
I have always heard of them bending where the knuckle ball and axle tube meet.
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
if the axle is bent where the knuckle balls meets the tube, your birfields will either not come out or go in, or will be extremely hard to. they are a tight fit as it is, but if you bend the axle tube, it becomes close to impossible quickly
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
You'll never take me alive
GM Man [OP]
  • Male Posts: 11
Thanks for the info I'll be doing my homework now...  I'm guessing that a axle ball gusset kit would take care of this??   :idea:
crawlerdan
  • Male Posts: 4,770
it will not fix a bent axle, no- and may CAUSE  a bent axle if you do not weld it correctly
heat= warp
warp= bend
Slolyfe
  • Male Posts: 2,048
  • Heyo
heat= warp
warp= bend
X2
The ball gussets prevent axle bending after installed, they dont fix an already bent one.
drayday55
  • Turtle Points: -1
  • Male Posts: 299
  • Member since Feb '09
try taking out the birfs.  if they are easy a pain to take out most likely you have a bent housing.
when i got my new one and slid the birfs in, i knew right away taht my old one was indeed bent.
it is easyier to tell empty on the ground.  it has a good arch to  it.  nothing that shows in pictures.
a local frame and axle shop said they could straighten it but  i decided to get a new one.
i always go to the local junk yards. ill pull one for you .
if you can wait till sale day its 1/2 off but it might not be there anymnore
Last post Jul 06, 2006, 06:06:11 PM
by yotaboy79
Last post May 07, 2009, 10:30:58 PM
by drayday55
Last post Oct 04, 2009, 12:57:54 AM
by 82juguete
Last post May 05, 2010, 10:00:16 AM
by 86moneypit
Last post Apr 09, 2023, 11:06:34 PM
by James874runner
