E-Brake
Started by Fireimp141, October 16, 2004, 09:58:34 AM
Fireimp141
I need to know what i can do to get my ebrake to actually hold, should i convert to a landcruiser? or wut
Thanx
Mike D
drive line E-brake for 195  :thumbs:
brainlessfool
well your stock E-brake should hold even with the oversized tires. check that
#1 your rear brakes are in proper adjment.
#2 your E-brake cable is not lose.
#3 your back brakes have any "meat" left and that there not covered in oil or brake fluid.
#4 keep a brick with ya at all times!  :smack:
hawaii500_1999
a properley working e-brake on your truck should work fine.
check out the thing Brainless mentioned.
another thing i have had problems with is the auto adjusters.  they never work right.  i even went as far as buying replacement parts from the dealer in efforts to get them to "auto adjust",  i tried to do the "drive in reverse and stomp on the brakes" method to get them to adjust but it just didn't work for me.
i finally gave up and just added, adjusting the rear brakes, in my normal maintenace routine.
usally two clicks every 6 monthes for my driving.
good luck
mike
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
Mike D
get a rear disc conversion with a good ebrake check it out at www.sky-manufacturing.com
A little pricy  :twocents:
KYOTA
Quote from: brainlessfool on October 16, 2004, 11:53:30 AM
10-4         got a couple of chunks of 4"x4"'s in the bed of mine
