wheel studs problem on my 84! pls. help me find the right ones!
Started by Sundowner, October 15, 2004, 06:08:56 AM
Sundowner
I have an 84 4Runner with a solid front axle.
I had to pound the piss out of the studs on one hub/disc assenmbly to get them out. I even had to drill one out thanks to the northeast road salt fetish.
now, I can't seem to find wheel studs, and it's driving me and my parts guy nuts. the catalog he's got says it's the same wheel studs from 84-95, but those studs do not fit, at all. they fall right through to the head. the studs I had in the truck were "almost" identical to a stud from an 83 TLC< but the knurl and hsank are both 0.01" too big to be driven into the hub. I can ream out the hub to 0.545" diameter to get these studs to work, but I'd like to know wtf is going on before I start removing metal.
backgroudn on the vehicle: I bought from a Toyota mechanic who had a sortof-notreally ide of what he was doing, and he bought it from a guy who really knew his stuff when it came to toyotas. I have not ruled out the possibility that some things on this truck may be non-stock.
what holds the rotor on?  Is it 2 bolts or 6.  That will tell the story right there as the earlier ones had different studs if memory serves.
88runner
next time take them out with a brass punch and a 2 pound sledge hammer work great onse you get it rigth 1or 2 blow and it's out, I removed all 12 of them last winter.
And I know what you're talking about we have those same problem here with the salty road.
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
leorn
man you guy really need to make a friend with a press, or pay a shop to press those out and in.  I don't know how I would have done mine without it!
Bring on EJS
I keep some cheap aftermarket tall acorn nuts around just for removal.  I just screw it on 5-10 threads and give it a whack.  Thats it and its a lot quicker than a press too. :gap:
Skinny_Pedal
Quote from: WHITE_TRASH on October 18, 2004, 04:45:25 PM
he did it to my truck, then it fell over
Im an OG
Skinny_Pedal
Im an OG
