rear axle carnage??
Started by 85yotabox, June 03, 2009, 08:12:48 AM
85yotabox
I hear a lot about front axles and birfs breaking but how often do rears break with 35-39" tires?  Ive never heard much about them.
Thanks,
Anthony
Chicks dig body damage!
build it to beat it!
_____________________
[  ]===TOYOTA===[  ]
my build:  http://board.marlincrawler.com/index.php?topic=51558.0
Rockcrawlintoy
not as often but they do break. i have never worried about the rear axles on my truck but i do worry about the ring and pinion.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
bigarms23
i broke 1 rear axle shaft with 39.5boggers with 3 tcases but havent broken one since
Slolyfe
I saw an 85 rear axle break with 35s and a detroit. He was going up a real steep ledge but very little throttle. It was interesting.
You'll never take me alive
Dingman.
I broke one driving on the street, in 2wd on 33's.
The catch was.  heat was used on the wheel bearing to remove the old one
moral of story, don't use heat on the bearings when trying to get them out.
Wermz84
Just because mine are so old, i carry an extra in my stationary box.
I like to Drive!
89sastoyo
They usually dont break but every once in a while they do it always seems to be wierd situations though. My friend broke his welded with 33s in a gravel pit driving. I bought my truck with a broken shaft and it was open in the rear with 35s.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
Bazzi
I have broken a few... actually more than birfs... I always had a spare, and the heat thing, I got one as a spare, with a new bearing, that one lasted a mounth or something, It´s always fun to loose a tire from under the truck...  I am driving 38-39,5 and arb´s and detroids  I have broken a few ring and pinions and 1 arb locker
I am running frontrangeoffroadfab fullfloating kit now and am LOOOVING it. since then I have broken 1 spindle
I am trying to find a pic for ya...
whokrz
I worry about my rear differential more than my birfs mainly because they are expensive. When I have the money I am going to try and make a full floating toyota rear axle using a 8.4 center and land cruiser outers.
1990 4runner, 22re, R151, 4.7, 5.29s, E-locker front, Lock-Rite rear, 37" MTRs, 51" rears all around
Trail Reviews http://www.gentryoffroad.com
Toyota Factory Service Manuals http://ncttora.com/fsm/index.html
yjay
Not to jack, but are both rear shafts in an ifs rear the same length? (For carrying a spare)
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
whokrz
yes but you may have to make mods to the brake
Kaptain
Quote from: Dingman. on June 03, 2009, 11:33:20 AM
It's my belief that this is the main reason that they do break.
If heat was never used to remove the bearings then the Third member becomes the weak link IMO.
junya92toy
I broke one, well a 85 year old man did. WHen he hit me with a saturn going about 50 as I was stopped.
BrotherGrim
I am running 36's and ARB's and stripped some my R&P teeth. I looked at the axles and I see no ware of any kind. I think the problem was the crush sleeve went. But I had that set of R&P and ARB for 10 years.
Proud member of Cal4Wheel, BRC, UFWDA, FOTR, and SEMA Action Network.
One of the founding members of NorCal4Wheelers.
Custom '89' 4 door truck, 36's, daul cases, ARB F/R, bla...,bla....,bla
'KI6ZFZ'
Dingman.
10years is a decent run..
Solid pinion spacer next time!
BrotherGrim
Solid spacer is already in place. Not a lot of people 10 years ago knew about solid spacers. Now it is the only way to go. I think I would been hard press to find one back when.
'KI6ZFZ'
miks85yota
ive heard of solidspacers, but not sure about em. what are they exactly are they, and where do u get em, is it somethin i can make?
Dingman.
Wermz84
Quote from: miks85yota on July 21, 2009, 10:05:31 PM
http://www.marlincrawler.com/differential/parts/solid-pinion-spacer-kit
:thumbs:
I like to Drive!
My neighbor twisted the splines on cleanly with an open diff on 33's...  :hahaha:
