Snorkel !?!
Started by WOLF, October 12, 2004, 02:51:35 PM
WOLF
I guys, I'am a new guy from the north. I'am not realy good in english and this is why I never try your forum.
But now I need some good idea from you Toy guys! I wan to put a snorkel on my truck to avoid blowing another engine. But i don't have a lots of money rigth now to spend on some Safari. Than, can you show my what is your setup (for those who got home made snorkel).
Thank!
89 4Runner
Dual T-Case
35 x 12.5 TrXus
Rear axle locked
How about this one?  Ive done the same thing to one with a 22r and it worked out good.  On a re youd have to tap into the air box and mount the snorkel to the driverside fender.
88runner
I'm sure you already know me  :gap:
but here's the link to give peoples some idea :idea:
http://toyrunner.net:8082/snorkel.html
Oh and don't try to read if you don't speak french  :eyecrazy:
:pokinit:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Prismo
I did basically the same thing as shown in 88runner's post. The fender helps keep water from the air intake tube and is higher than the stock location. I set the intake at the back of the fender as high as I could put it. I also used a small piece of heavy window screen over the mouth of the tube.
toyotaboy
im laying in my gas door into mt hood and will be running an rv sewage tube front the door over and the roof ill take pics when i get around to building it:) And the whole bad english thing.... its all good.. no one here will give a bad time for not speaking well... if we dont understand well just ask ya to try expaining it again... no worries dude ask away and everyone here will do there best to help you out.
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
WOLF
Thanks toyotaboy, I'll try to practice my english whit you guys.
And good to see you there 88runner, I think I'll do some thing like you but maybe whit a hole up the fuse box ::)
But don't stop to show your set up (whit photos please, than I'll can figure out how the tube goes out of the fender!)
89 4Runner
Dual T-Case
35 x 12.5 TrXus
Rear axle locked
Fireimp141
I think for mine im just gonna run it like the PVC, but use that underground black hard plastic stuff, dunno what it is  :hammer: but i might just drill a hole in the side of the fender and make it exit there, with like a shower drain type thing or just some heavy duty mesh to cover it, that way it gets cold air, or i might just leave it inside the fender, dunno :dunno:
toyhatsu
three three inch dia mandrel bends, a couple of pieces of exhaust pipe and a Safari hood.
1991 Daihatsu Rocky, 3RZ-fe, Marlin super heavey duty clutch and pressure plate, Marlin W56-C-HD, duals, Marlin twinstick, three link front with Fox AirShox, 35's, Toy axles, 5.29:1, ARB F&R etc.
toyhatsu
holes and stuff
toyhatsu
misc
toyhatsu
cut the flare off of the 90* and weld it to a plate.  Cut some slots and use a band clamp for inside the fender.
Fireimp141
Can u post some close ups of the hole in the fender? also where are those holes inside ure truck?? and is that one clamp for the intake at the mass 02 sensor? And ure actual tubing is just 3" piping? Thanx alot for the help, im planning on making myself one  :beer:
hessiankid31
Hey, do not worry about your English. It is moult meilleur than my Francias~ .Here are some pictures of my snorckel.
It works puits well and I will be glad to help you anytime. Just private message or E-mail me. Bon Chance
Its not "AT" anywhere! 91v6 Toy sawzall special w/ twin turbo thrack-u-lators, 01 Taco4cy cream puff,85 220whp 5mge Supra,multiple FF Honda civics
hessiankid31
hessiankid31
davantage
hessiankid31
davantage
hessiankid31
davantage
hessiankid31
davantage
hessiankid31
davantage
brainlessfool
And as pic. ten shows you have a ready made vac. for those pesky penunt shells that litter up the cab!  :beerchug:
hessiankid31
not only that, I also have an engine stethescope, leaf blower and conversation blocker.
hessiankid31
davantage
hessiankid31
 fin :sleeping: I'm really happy with this setup, because it allows me to switch between snorkel and open air in engine compartment in under five minutes. The only change I'm making so far is a switch to bent thick-wall alum. piping in place of the ghetto-vac!
toyhatsu
#23
Quote from: Fireimp141 on October 14, 2004, 09:41:29 AM
The hole in the fender was cut with a 3 1/8" hole saw and a big half round file...file and fit, file and fit etc.  The gasket is rubber car door edge moulding.  I used black silicone around the gasket and the pipe.  Yes the band clamp and slotted bracket is for the inside of the fender in the engine bay.  I put a bunch of silicone on the backing plate of the bracket, pushed the snorkle tubing through tight against the body and put the band clamp on till dry.  I would think that you could put the MAF sensor just about anywhere between the pipe in the engine bay and the intake manifold.  The Rocky didn't have a MAF sensor.  The other holes are in the door pillar at the front windsheild.  I used some one inch plastic hole caps I found at the hardware store.
I don't like the way the lines of the snorkle turned out but I cut it all apart once and welded it all back together.  There are eight welds in it now.  I do like the way it hugs the body.  If you do this you might have someone help you as it is hard holding the pipe at the right angle and tack welding.
I am having a 3RZfe installed and the intake is on the oposite side...haven't figured how I will tie it into the snorkle yet.
Bazzi
Do you guys know where I can find a place to buy the top of the snorkel??? I just wanto buy the top!
WOLF
You all have god idea but I started the one that I had and the job is almost done. I took some pic and post it later, maybe in a couple of weeks.
89 4Runner
Dual T-Case
35 x 12.5 TrXus
Rear axle locked
Mike D
Man i really like that setup and it looks just as good as a 200 dollar snorkel :thumbs:
toyhatsu
Quote from: Bazzi on October 15, 2004, 05:24:08 PM
Bazzi,
Me mate in Oz sent that to me.  He bought it at an ARB store for $35.00 US.  I think that if you contact ARB or Safari and let them know what you want they should be able to help you.  Geez all this time I have been spelling snorkel wrong :_oops:
hessiankid31
By the way, I really like toyhatsu's design, it is much cleaner and more "finished" than mine, by a long shot. Mine works GREAT and I'm happy with it, but it's not what you'd call a smooth design from a looks point and the flexible piping is a weak point.
I love toyhatsu's rig. Never thought I'd say that about a rig with an angry sneeze name, but it is tre' cool!
toyhatsu
Quote from: hessiankid31 on October 18, 2004, 07:49:30 AM
Ha, an angry sneeze...I like that.  That's much better than what most people say about it which I can't write here because of the obscenities.
