Pull the wire off the distribution block and see if it turns off.
Have you tried pushing the e-brake switch with it connected to see if the light goes out?
Where is the distribution block? Are you talking about the plug in the back of the speedometer housing?
its possible the float in the cap is no longer floating. Mine did that so I did what any reasonable person did. I unhooked the wire.
Help me figure this out, I talk to an old toyota mechanic and he tells me to rebleed the entire brake system and then stomp hard on the brake. According to him this will correct an imbalance in the system and shut the light off. SO I bleed the brakes, stomp on them as hard as I can a couple of times, and then this morning the light is off. I haven't driven it for three days so it sat for a while but the light is off. Anyone ever hear of anything like this?
Started by chevyLUVtoyota « 1 2 » Engine
Started by mudweiser Toyota Pickup/4Runner Tech 1979-95
Started by Thomas P Toyota Pickup/4Runner Tech 1979-95
Started by yota_krawler Engine
Started by Tofudude Parts Wanted
