Author Topic: 3rd gen runner sas  (Read 3760 times)
Misfit4Runner
  • Male Posts: 313
  • Member since Jul '07
  • This line intentionally left blank
3rd gen runner sas
« on: May 12, 2009, 10:04:57 PM »
Here's what I got 97 4runner sr5 5spd 3.4 under the hood
Plans:
Sas either full widths or smaller 44
Have hd 44 68 wms and a d70
Leafs marlin 4in mabey 5"
Dual cases
35s but leaning to 37s
Custom bumpers and of course locked
Bottom line I'm going for mossys rig but I'm keeping the back
I'm looking for and good advice as of now don't think I'll go hysteer and keep it like eriks runner
This rig still has to stay streetable as I can't always ride to work.
Mostly going to be a all around rig not just a rocker
If you dont stand behind our troops, Please feel free to stand in front of them.
88 xtra cab sas'd dual cases flatbed
dniel
  • Male Posts: 194
  • Member since Feb '09
Re: 3rd gen runner sas
« Reply #1 on: May 13, 2009, 08:43:57 AM »
If you are going full width you should go with a d60 front from the start. The extra cost is not that significant in the overall price of building a rig. Run toyota RUF and f150s in the rear. This will save enough money to help offset the price of the 60 and and with the weight of the axles will work as well as anything you can buy. The only downside of a front 60 is you lose some clearance but since you are running a 70 rear this shouldn't be an issue. If you're looking to be a little narrower get a dodge front 60 instead of a Chevy. They are a couple of inches narrower and usually a couple hundred $ cheaper.
1uz-fe, 1 tons, 44" tsl
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #2 on: May 13, 2009, 03:56:22 PM »
Eventually I will go 60 but just for now I'm sticking with the 44 as I got it for only 100 bucks but I'll keep my eyes out for a dodge front 60 for when the time comes
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #3 on: May 13, 2009, 03:58:22 PM »
On that though how much lift can I expect out of rug and 150 in back n what about some Chevys?
  • 96ZJ v8
  • Turtle Points: -415
  • Male Posts: 4,823
    • Buy me a drink
« Reply #4 on: May 13, 2009, 05:07:30 PM »
:worthless:
Can't wait to see this bad boy.
dniel
  • Male Posts: 194
« Reply #5 on: May 13, 2009, 05:33:06 PM »
You can make it what ever you want. The toyota rear springs up front would give you very little lift if you just used the stock 3 leaf pack with the over load removed. You will need to add a couple leafs to gain a little lift if you want to run high steer. If you are going to run some kind of low steer you can run a much flatter pack. As for the rear I don't think the f150s would give you alot of lift as the 4runners are pretty heavy. The most important thing is to figure out what main leafs you want to run. You can put what ever you want under them to get the ride height you want. Use the top two rear toyota leafs up front. They are very flexy and give you miliyary wrap.
As for the rear go to the pick and pull and have a look around. F 150s, s10, and rangers are all about 57" long and have similar arch. Keep an eye out for bronco II springs. These have more leafs than f150s so you can remove a leaf or two if you want less lift.
This is my brothers 4runner. It has toyota rears up front. Probably 3" of lift. This is about as low as you can go with high steer and an IFS frame.
  • 96ZJ v8
  • Male Posts: 4,823
    • Buy me a drink
« Reply #6 on: May 13, 2009, 05:38:09 PM »
what does he have in the rear?
dniel
  • Male Posts: 194
« Reply #7 on: May 13, 2009, 05:51:24 PM »
They are 51" rears from a 89+ toyota pickup. They are very soft and he had to add a lot of leaves under them because he carries lots of tools for work. I am going to run a stock 3 leaf 51" pack in the rear of my truck but I don't care if it sits lower in the rear than the front.
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #8 on: May 13, 2009, 09:55:22 PM »
the truck in my avatar had rears up front frankenstien pack. 1 in front hanger and 5.5in bannana shackles and ran 38's so i should be ok with rears. might go with chevys out back due to the weight though as I pull a small trailer sometimes. im also going to run lo steer like eriks http://home.4x4wire.com/erik/4runner/sas/#steering
but when I go to a 60 ill take the time and go hyd
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #9 on: May 15, 2009, 08:05:42 PM »
here are the axles. Ill shave the rear of course. I figure I can get about 1 1/4" before I have to take down some of the ring gear.
As it sits now
The parts im going to be selling
OME 890 coils
80 land cruiser coils
billistien coil overs
1" diff drop
ifs crap
265/75/16 goodyear wranglers
ifs rear end (open)
"mabey stock fuel tank"
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #10 on: May 24, 2009, 02:30:28 PM »
alright I have the axles torn down going to need new rotors, calipers, U-joints, ring and pinion have a 4.10 in their but im thinking 4.88's to run 35-37" on the street?  also going to need new seal bearing are done with timkin.
Stuff to order.....
Hy steer arms
marlin 5" springs
front hanger
shackles
Craigslist finds
e150 gas tank
mabey toy rears and 63 chevs to build up so I can save some cash so i can rotate and dual Tcase.
Anything else im missing just to get it sitting?
Also I need help finding a good company that seels rebuilt kits for ford dana44's
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #11 on: May 24, 2009, 02:36:03 PM »
put the FZJ-80 Land Cruiser Coils under the 4runner for shits till i cut it all off so I have some OME 890 coild with spacer for sale
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #12 on: Jun 06, 2009, 09:23:11 AM »
Got my tires 4 brand new never mounted 37" hummer tires I decided to keep it full width so that meens 8 lug I think I'm going to go with hummer rims too as I can get the double beedlock and parts easy. Due to the lockout in the front being so huge I might have to recenter or run spacer or mqbeu some new warns will be a lower profile? Still on the hunt for some toy rears and Chevys
LilChief87
  • Turtle Points: -1
  • Male Posts: 917
  • Member since Jul '08
  • When in doubt Romp it out
« Reply #13 on: Jun 06, 2009, 01:21:12 PM »
get 5.29s if your gunna run 35s or 37s with 5.29s and 35s itll be basically like runnin with stock gear  so it will still cruise good on freeway nd everything
dniel
  • Male Posts: 194
« Reply #14 on: Jun 06, 2009, 01:33:35 PM »
How much are you paying for the hummer tires and rims? I have been unable to find a good source locally so I will probably have to have mine shipped. If your running the 37" radial make sure to get the 12 bolt rims. The 8 bolt rims are not meant to hold the higher psi and can come apart with a radial tire.
yota_krawler
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #15 on: Jun 06, 2009, 02:05:39 PM »
it has a 3.4 doesnt need that much gearing. + they dont make a 5.29 in dana axles
thegoofster21
  • Male Posts: 1,644
  • Member since Mar '08
  • HIT IT HARD!!!
« Reply #16 on: Jun 06, 2009, 02:51:02 PM »
im sure he means 5.38. i hope
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
LilChief87
  • Turtle Points: -1
  • Male Posts: 917
« Reply #17 on: Jun 06, 2009, 03:41:17 PM »
yeah there we go  :thumbs: i didnt realize it until just now
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #18 on: Jun 07, 2009, 05:45:39 PM »
thanks for the help on gearing I need this thing to take me to work once a week 100miles round trip. As for the tires I paid 150 for all 4 and rims I can get free or pretty cheap.. mabey 100 bucks for 5 plus another tire.. gotta have a spare. Unfortunatly I cant really hook anyone else up with the same type of deal. but if you all ver look on ... cant belive im about to spill my beans  :smack: on govliquidations.com their are some outstanding deals to be had.  from running gear like dana and rocks to full on 6x6's tracktors tools tires anything  :bowdown:
Also if anyone has some chevy springs and toy rears they want gone from their pile I got a case of beer  :beerchug:
Tires  in my nasty garage ill go clrean it as soon as i post promise.
Misfit4Runner [OP]
  • Male Posts: 313
« Reply #19 on: Jun 17, 2009, 10:21:55 PM »
5.13 gears are the best I'll be able to do that's the only combo I can get with my 70 rear. Bout I orderup some hangers, hoops and tabs soon. Still trying to get ahold of some rims and springs are pretty tough too
Last post Jul 02, 2003, 09:39:46 AM
by BMFN_TOY
Last post Nov 07, 2009, 06:49:41 AM
by Joey88RUNR
Last post Sep 09, 2013, 09:15:57 AM
by H8PVMNT
Last post May 12, 2013, 09:01:47 AM
by robert.levi
Last post Jul 12, 2012, 07:12:49 PM
by fullsizenomore
