are you runnin air shocks, coilovers or what, also you runnin a sway bar
can someone show me pics of this ors kit... My setup is home made Icelandic garage thingy... and I have been messing around with it so much that it isnīt really pretty any more.
watched a good demo of this on spike tv last weekend. xtreme 4x4, dig it up it will answer your question.
if you have room under there and it was mine, I'd bend a piece of tube and make a crossmember and swing those lowers in at the frame. Did you happen to look at mine at the hammers? dual tri and it did awesome I was very happy with the way it performed. oh yeah you have the gas tank to deal with still & thats why you went single tri with straight lowers? are your uppers adjustable? if so start playing with location. I thought your runner did well but I wasnt in the seat edit: is that your gas tank in the back?
put a sway bar on it and it will be fine. I'm running air shocks and it works great get rock equipment they have a sway bar for the tube that holds the gas tank in the rear goes right inside
to get rid of the squat i would say make the links a parallel as possible, but i know from experience that a perfectly parallel 4 link get very crappy tracsion. i would try a winch for the rear, cheap and easy and if it doesnt solve your problem you still have a winch back there
you will get some better opinions if you post a good side pic ,at ride height. That way we can see how your suspension is set up.
id lift up the frame end of the uppers a little bit and make the mounts adjustable so you can play with it a little bit. Looking from the side imagine your links are really long, they shouldnt intersect untill at least the very front of the truck or else you are going to get the issues your talking about. Also a sway bar helps alot if your still not happy
Started by booger_weldz Engine
Started by 84runner Engine
Started by notajeep Engine
Started by Travis@DOI « 1 2 » Project Research and Build-Ups
Started by KWP « 1 2 3 » Engine
