compression check #'s
Started by superyota, May 06, 2009, 05:07:34 PM
superyota
i did a compression check on my 85 22r converted to re motor just to see what the numbers are.  i warmed it up first, then pulled all the plugs out and checked each one at wot.  all cylinders came out around 155 psi +or-  2 lbs.  is this about normal for a rebuilt motor with about 50k on it?  seems kinda low to me.  anyone have #'s of their motor?
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
thats good numbers
what was the outside temperature and humidity??
superyota
it was actually a warm day,  don't have a clue on humidity.  its in bakersfield, so i'm guessing around 0
ABD Motorsports
#4475
KK6QDW
According to TOYOTA, those numbers are fine
superyota
cool, thanks for the info.  i just remember doing a compression check on the motor about 2-3k after the motor was rebuilt and it was aroun 185.  i was expecting it to be up around that.  but according to the manual, i'm good.  is there anything easy to do to get the compression pushed back up a bit(head gasket, valves, etc) that is worth the trouble?
ABD Motorsports
#4475
KK6QDW
what is wrong with where it is at?
nothing you can do without reaing the engine apart.....
you can deck the head and block, install oversized pistons, etc
superyota
its good where it is, i was just curious what it was supposed to be at if it was getting to the point to where i should start thinking about rebuilding it or not.  i guess i'll be good to go for a while longer.
ABD Motorsports
#4475
KK6QDW
emsvitil
Quote from: superyota on May 06, 2009, 06:42:32 PM
Time and carbon buildup.........
I get 195-200 on my 86 with 165,000 miles............
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
superyota
ABD Motorsports
#4475
KK6QDW
