Author Topic: how to i.d. a bent front axle?  (Read 3262 times)
drayday55
  • Turtle Points: -1
  • Male Posts: 299
  • Member since Feb '09
« on: Apr 28, 2009, 11:23:04 PM »
any one know any clues? measurments how to take them to see if axle is bent?
chalk line? anything like that?
Steve_925
  • Turtle Points: -86
  • Male Posts: 1,876
  • Member since Feb '07
  • F***in catalina wine mixer
Re: how to i.d. a bent front axle?
« Reply #1 on: Apr 29, 2009, 01:20:50 AM »
well if you have any trouble getting the birfs in or out thats a good signh of a bent housing. as far as measurments im not sure.
UA 342
STEAMFITTERS
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #2 on: Apr 29, 2009, 08:29:40 AM »
Usually they bend at the inside end of the bell that is the smallest area of the housing, Marlin has a kit to fix that issue that is a weld in deal.
Slolyfe
  • Turtle Points: -117
  • Male Posts: 2,048
  • Member since Aug '07
  • Heyo
« Reply #3 on: Apr 29, 2009, 09:25:56 AM »
I had an inner seal that I could not get to stop leaking. Turned out to be a bent housing. If that helps
You'll never take me alive
drayday55 [OP]
  • Turtle Points: -1
  • Male Posts: 299
« Reply #4 on: May 01, 2009, 09:48:58 PM »
hmmm,  I'm sending my truck to a local guy to do the front axle.  I'm just worried  the camber is bad because of a bent axle and not the kingpin Bering's.   i know the passenger side is blown, it has 1/8 of play but would that make the camber be out that much?
Yotaman80
  • Turtle Points: -12
  • Male Posts: 384
  • Member since Dec '06
« Reply #5 on: May 02, 2009, 04:07:38 PM »
Just for your info they arent technicaly king pins they are call turnions. you should rebuild it yourself its really simple and there is alot of help on the board here that can help you if you run into any trouble. Then if you break down on the trail you know what to do to fix it just my  :twocents:
80 Mini Truck-6" springs, Custom Cab Cage, 5150 Bilsteins, 5.29 Yukons, Aussie Locked, Warn M8000, 35"MTRs 5-Points, Diff Breathers, Sliders, Custom Front and Rear bumpers thanks to FATKID
Build Up- http://board.marlincrawler.com/index.php?topic=50320.0
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
  • Member since Feb '05
« Reply #6 on: May 02, 2009, 04:15:17 PM »
the birfs are a super tight fit, as you may already know, if you have a proper seal, if takes effort to get a birf in if it ISNT bent, i warped one of my first ones welding and it moived just a little, and i couldnt get the birf in. leaking seals is a good indication also
potter85
  • Male Posts: 257
  • Member since May '09
  • complete disregard for sheet metal.....
« Reply #7 on: May 07, 2009, 06:33:02 PM »
my inner driverside seal leaks too. probably due to the fact that i destroyed the innes shaft birfield and hub all at the same time :( maybe it is bent but my housing is pretty scarred up from when it all came apart. I got 4340 chromo inners and birfields from poly performance now :) no more problems
3rz in the making
looking for 38s
2 tundra 4.7l v8 soon to be sas'ed
drayday55 [OP]
  • Turtle Points: -1
  • Male Posts: 299
« Reply #8 on: May 07, 2009, 10:30:58 PM »
i just ordered the 54mm socket , eather gonna do timing chain or birfs this next week.
darn it,, i cant for the life of me have peace of mind until this stuff is done and done perfectly!
I'm worried that ill wast my time with the axle rebuild and have a bent one,
timing chain is a ton of work, hate to do it and need to pull head soon after to fix something else.
motor seems sound, just idles poorly.  it idles good with a/c so seems like a vacuum leak or egr problem.
thanks for the advise
Last post Sep 23, 2002, 04:37:52 PM
by MD11Fr8Dog
Last post Jul 06, 2006, 06:06:11 PM
by yotaboy79
Last post Jun 22, 2009, 10:19:41 PM
by drayday55
Last post Oct 04, 2009, 12:57:54 AM
by 82juguete
Last post May 05, 2010, 10:00:16 AM
by 86moneypit
