pulling engine/tranny/t-case in 1 shot?
Started by kyle_22r, October 05, 2004, 09:18:11 PM
kyle_22r
well, the title says it all.  is it possible, or would it just be easier to unbolt everything and pull it out piece by piece?
Skinny_Pedal
i think it would be easier to drop the tranny and tcase as a whole and then the motor. i remeber pulling a 22re and tranny out of a 85 celica, what a pain
Im an OG
Prismo
I have done it that way once. Had to get the engine & tranny pointed almost at a 45 degree angle to clear the radiator support. That was with the truck front on jack stands for more room. Have not done it that way since. unbolt tranny/pull engine nowdays.
kyle_22r
alright, sounds like i'll be seperating things :biggthumpup:
does your average tranny jack work for getting everything high enough to bolt the x-member on, or am i going to have to get creative? :flamer:
Prismo
I have used the tranny jack, mine barely reaches, depends on your tire size. I have also used a 3" rachet strap in a pinch on the side of the road.
BLUCRUZ
FSM says take it out as a whole unit? I tried it in the driveway and my Hoist almost couldn't handle it until I let all the air out of the tires. The angle really sucked taking it out and over the Rad support especially with the dual case set up. If stock height go for it, if lifted make sure your hoist will go high enough. :twocents:
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
