Author Topic: quick radiator question  (Read 1571 times)
JoeWelder
  • Turtle Points: -4
  • Male Posts: 146
  • Member since Jan '09
  • Tonka
« on: Apr 13, 2009, 06:21:45 PM »
im thinking i need a new radiator but i want to make sure.....usally you can run a vehicle with the cap off and its fine, but after a few minutes, mine will start flowin out the top. my truck did sit for a long time (years) so im thinking its cloggd up with  :pokinit: ive washed it out with a hose but its still doing it....also a guy at work said it could possibly be a blowin head gasket??
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: quick radiator question
« Reply #1 on: Apr 13, 2009, 06:23:44 PM »
thermostat can cause that.
JoeWelder [OP]
  • Turtle Points: -4
  • Male Posts: 146
  • Tonka
« Reply #2 on: Apr 13, 2009, 06:25:03 PM »
i thought of that....so i took it out, but its still does it
  • Momentum Man
  • Lego Enforcement
« Reply #3 on: Apr 13, 2009, 06:29:24 PM »
Does it run hot or normal, if it is running hot may be the pump. Usually if it is a blown hg it will do it from start up on.
« Reply #4 on: Apr 13, 2009, 06:30:37 PM »
pull the thermostat and run it without one just to see if it forces the water out, if it does :ack:  you have a blown head gasket
yotabj
  • Turtle Points: -15
  • Male Posts: 116
  • MAD FLEX YO!!!!
« Reply #5 on: Apr 13, 2009, 06:31:56 PM »
Have a radiator shop clean it, I bought a used rad. for my s10 and flushed it many times and never got it clean. I took mine and he said it was prolly the worse radiator he had ever cleaned.
'84  Truggy EFI swap ,5.29's Detroit,welded,Dual Ultimate Cases,22re,3 in. downey,4 in.Marlin Front springs on back  114 wb ,39.5 Rockers,30 Spline Longs
JoeWelder [OP]
  • Turtle Points: -4
  • Male Posts: 146
  • Tonka
« Reply #6 on: Apr 13, 2009, 06:33:57 PM »
it got real hot when the thermostat was in, even with out it in, after about 20 seconds of starting it, it start flowing out, if i gave it more gas, more comes out....i also replaced the pump
JoeWelder [OP]
  • Turtle Points: -4
  • Male Posts: 146
  • Tonka
« Reply #7 on: Apr 13, 2009, 06:35:04 PM »
i did run it for about 15 minutes with out the thermostat in and it defintly helpd, it didnt get nearly as hot
93tonkatoy
  • Male Posts: 463
  • Member since Jul '07
« Reply #8 on: Apr 14, 2009, 06:05:42 PM »
All of this can be done easier without the t-stat installed!
To tell if it IS your head gasket, start with the engine cold, fill the radiator, disconnect the overflow tube from the overflow tank, then crank the truck an let it run (and rev the engine hard a few times - not for high revs, just quick full open/close throttle bursts) for 45 seconds to 1 minute (not enough time to get the coolant hot). Watch what comes out of the overflow. If you only get small drips of water, then the coolant is expaning as it heats. If you get "geysers" of coolant coming out, especially when revving the engine, possibly followed by air, then your HG is blown. Immediately after you shut off the engine (BEFORE THE ENGINE GETS HOT) open the radiator cap. If you get pressure release, it is the HG.
Also, with the cap off, and the engine running, check to make sure you have coolant flow across the radiator. If not, check the radiator core and the water pump.
SAVE TELLICO post 491
Last post Apr 26, 2005, 05:28:21 PM
by germ
Last post Jul 02, 2005, 07:50:28 PM
by 79coyotefrg
Last post Apr 03, 2007, 08:11:51 AM
by weirdtimes_7
Last post Dec 17, 2008, 09:15:54 PM
by Rocksurfer
Last post May 06, 2013, 08:31:45 PM
by Dirt Mover
