Author Topic: 93 pickup 22re timing  (Read 2586 times)
81flatbedcrawler
  • Member since Apr '09
« on: Apr 13, 2009, 03:18:26 PM »
I have a 93 pickup with a 22re engine. It had a blown head gasket and when i finished putting it all back together it will crank but not without giving it gas. It wont idle when it hits about 3000 rpm it sounds good. I dont have any aparent vac leeks but maybe crossed. If the cam gear is off a tooth will it still crank?
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
Re: 93 pickup 22re timing
« Reply #1 on: Apr 13, 2009, 04:28:37 PM »
well i :welcome: to marlin  and sorry to here your mis fortune.
here's a online manuel http://www.ncttora.com/fsm/1993/engine.html
with the crank on TDC   where is your top mark on the cam  it should be off to the left  a little   also  check that the rotor is pointing at   #1 wire on the cap
« Last Edit: Apr 13, 2009, 04:37:46 PM by drunckle »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Apr 13, 2009, 08:26:28 PM »
yes it will but  it wont run too good
remove the valve cover, then put the crank pulley timing mark on 0*, then look at where your cam timing is at, the cam mark should be about 1/2 a tooth to the left (as looking at the engine from the front) of 12 o clock
Last post Mar 11, 2007, 06:35:33 PM
by wrenchtech
Last post May 17, 2007, 08:11:15 PM
by highridin4x4
Last post Dec 11, 2011, 05:46:22 PM
by I.D.G.A.F
Last post May 05, 2009, 09:32:36 PM
by havik
Last post Nov 12, 2017, 04:21:40 AM
by Lance davis
