87 4runner tcase ?'s
Started by jspd234, April 08, 2009, 11:10:39 PM
jspd234
has anybody done a twin stick install WITHOUT REMOVING the tcase from the truck? i have a 3" body lift on as well so i was thinking it might be possible because of the extra room around the tcase. anybody with actual experience doing this, please let me know , thanks! jeff
CrazyYota
you can install it without taking out the tcase but its not going to work. because you need to take apart the Tcase to remove the interlock pin its on step Step 72  :beerchug:
http://www.marlincrawler.com/tech/4701-gear-install
jspd234
thanx 4 tha info....i believe i saw that where the shaft has to move outside the end of the case to remove the interlock pin, thanks again
CrazyYota
