Author Topic: elec fan recommendations  (Read 3345 times)
66cobra
  • Turtle Points: 34
  • Member since Mar '08
« on: Mar 24, 2009, 05:50:47 AM »
 what cfm elec fan/s are you guys runnin i  have 4.3l @225 hp at the fly ,85 runner, a/a  aluminum radiator full exo and dual winches@tcases so there is alot of additional weight on my rig.jegs has one which puts out 3200 cfm, i,m thinking that should be more than enough but will be a tight fit and am wounderin if something in the 22-2500 range is sufficient. :turtle:
it's not me, it's you
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: elec fan recommendations
« Reply #1 on: Mar 24, 2009, 06:02:47 AM »
I run 2 10" at about 2600 CFM total with the stock chevy radiator, and never had a problem.  Thay are on a t-stat and turn on at 180,  which takes forever.  If that helps.
Snowtoy
  • Turtle Points: 1403
  • Male Posts: 2,583
  • Member since Sep '03
« Reply #2 on: Mar 24, 2009, 03:41:48 PM »
You want a fan rated for your HP, not necessarily just cfm flow.  IIRC, when I bought my Black Magic e-fan it was rated top 225hp w/A/C.  I would just give Summit or Jegs a call and see what they say.  You might also need to consider running two fans, one as a puller(traditional location), and one as a pusher(in front of the rad), if a large one wont fit between the rad and the engine.
wakkjobb
  • Turtle Points: -18
  • Male Posts: 1,590
  • Member since Dec '08
  • Back at it after 5 years!
« Reply #3 on: Mar 24, 2009, 04:13:31 PM »
Poke around your local junk yards; the Cadillac Catera comes with 3 fans; 2 pushers are big and thin and the third is a small puller and thicker. I used the 2 big ones on an 80 Chevy K10 with no problems; one was temp-operated and the other was on a switch... no problems at any temperature/condition.
They're big though; not sure how much room you have to work with...
... :twocents:
Good luck
Dan
Quote
IronClad: If I wanted to hold hands and be nice I'd become a hippie.
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #4 on: Mar 24, 2009, 04:31:38 PM »
Run the biggest fan that will fit.    Better to have too much airflow than not enough.
Also an adjustable temp sensor lets you put the turn on point where you want it.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
yota_krawler
  • Cody Hunter
  • Turtle Points: 5
  • Male Posts: 3,379
  • Member since Oct '06
  • proud parent!!!
« Reply #5 on: Mar 24, 2009, 07:00:33 PM »
I recomend NOT running one!
it doesnt give any more power, they are unpredictable, and unrelyable.
I went in the snow on saturday and it jammed up with snow and caused the fuse to blow. I got WAY hot and I didnt know why. I thought I wanted an electric fan until I got one. It is lagit too, not some ghetto install. I have a 2 speed electric fan for sale if you are interested. It is the same demensions as a stock fan shroud.
Snowtoy
  • Male Posts: 2,583
« Reply #6 on: Mar 24, 2009, 07:36:35 PM »
Yes they can be problematic.  I wire mine to come on w/the ignition. no temp setting required, not t-stat to fall out of the rad, and no t-stat switch to go bad.  It is basically fool proof, and as loud as it is I would know as soon as it went off.  The dealer was concerned that it might cool too well, and make the truck run cold, but the after market temp gauge is at 210 on the return to the rad, and the stock gauge runs at the same spot as it did w/the belt fan.
Getting snow packed in it is new one though, I am assuming it was set up as a pusher and not a puller.
wakkjobb
  • Male Posts: 1,590
« Reply #7 on: Mar 24, 2009, 11:14:10 PM »
I'm still on the "big as you can fit" side; I took that K10 through some deep snow/mud and didn't have any issues with either of the fans.
How's he going to run a stock 4.3 clutch/belt-driven fan? How much room is there at the front of the engine? I'm not familiar with the details of that swap...  :headscratch:
You could mount the radiator behind the cab and run a few electric fans there; less chance of snow packing...
BTW that K10 had a built 383 stroker with an auto trans and 4.56 gears... still no problems with overheating; even up long grades in summer (Colorado hills--7,000 feet up to 12,000 feet; Weston Pass). Wired the one temp switch into the intake by the t-stat housing and had no problems from it or the one that was switch-activated. Just kept an eye on the super-awesome SunPro temp gauge... hardly had to turn on fan #2 at all.
Again,  :twocents:
Do what keeps your engine cool!!
Dan
Quote
wakkjobb
  • Male Posts: 1,590
« Reply #8 on: Mar 24, 2009, 11:16:14 PM »
Quote
I loved pulling into fuel up and listening to the twin fans wind down... made a few people look over like "What was that?"
Dan
Quote
66cobra [OP]
  • Turtle Points: 34
« Reply #9 on: Mar 25, 2009, 05:35:04 AM »
I hear what you'rs saying on the reliability issues on an electris fan,but unfoutunantly there isnt a whole lot of room.I think i will go with the 3200 one in jegs and run the varible speed controller set up .I used a similar set-up on my cobra and have had good luck with it.thx for the input
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
« Reply #10 on: Mar 25, 2009, 06:09:44 AM »
x2
I luckily have the option to run the stock clutch fan or electric on my 4.3 swap.  I still run the electric, cause its a better cooler,  I also ran electric in my previous two motors by choice, so my fans have never gave me a problem in the ten years I have been running them (yes same fans).
ExplorHer
  • Turtle Points: 27
  • Male Posts: 16
  • Member since Mar '09
« Reply #11 on: Mar 25, 2009, 07:11:32 AM »
Was it a pusher fan?
boobap
  • Turtle Points: 160
  • Male Posts: 87
« Reply #12 on: Mar 25, 2009, 09:39:53 AM »
Quote
it pushes air through the rad instead of pulling it through
An eye for an eye makes the world blind.
ExplorHer
  • Turtle Points: 27
  • Male Posts: 16
« Reply #13 on: Mar 25, 2009, 01:33:40 PM »
I'm just thinking that if he had a puller fan inside the engine compartment, he wouldn't have had that problem  :headscratch:
wakkjobb
  • Male Posts: 1,590
« Reply #14 on: Mar 25, 2009, 10:24:06 PM »
Sounds like it...
I stuck a Volvo fan on my girl's 79 and she's been good with it as a DD for over a year now. We have taken it over 12,000 feet
...we drove up the trail behind the sign a ways so it's higher than what the sign says.
and it's been through some water:
It took some modifications but I got it to fit. This is with the first try at a 'better' radiator from the same Volvo, didn't work that well... went back to stock radiator.
So get an electric fan...
/my 2 cents
Dan
Quote
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #15 on: Mar 26, 2009, 12:28:37 AM »
I HIGHLY recommend you use a fan controller (automatic speed controller) to save your alternator, relay, and battery.
I have a Delta Controller on my e-fan setup and I would never go electric without it: http://www.dccontrol.com Unfortunately, their seem to have gone out of business?
Here is an archived version of their site dating back to Spring 2007: http://web.archive.org/web/20070304150513/http://www.dccontrol.com/
Here is an archived page with some info on the advantages of a variable speed controlled e-fan setup:
http://web.archive.org/web/20070928193904/www.dccontrol.com/introf2.htm
Here is a pretty nice write-up I posted back in 2006 on this subject:
http://board.marlincrawler.com/index.php?topic=22660.msg243208#msg243208
Good luck!
Last post Mar 08, 2003, 12:58:34 PM
by rEdnECkwHeE1eR
Last post Jan 29, 2004, 10:31:00 PM
by 4.3 headache
Last post Feb 26, 2004, 06:03:23 AM
by Krylon
Last post Nov 08, 2005, 08:10:40 AM
by longzuk
Last post Jan 24, 2011, 05:49:25 PM
by vincesyota
