Tire wearing problems
Started by junya92toy, March 14, 2009, 05:31:56 PM
junya92toy
I have a 92 toyota sas ex cab. 5.5 lift springs and boomer rang shackles. I just replaced the draglink ends. Im going to replace the tie rod ones soon. The problem Ive had for awhile is I wear the inner tread off the tires. I need to fix this of course. Any thoughts, yes I will get a alignment when I replace those parts
it needs an alignment  simple as that
slabcs
It's SAS'ed so the only thing they can change with an alignment is the toe.
If you're wearing out only the inside tread on your tires, your axle housing could be bent.
Relentless
KYOTA
yep bent axle
somebody took it off some sweet jumps
junya92toy
Actually sitting in the driveway it looks good as for camber, i did a quick tape measure and the front is like 51 inchs and the rear is 50 so its toed out bad. the inner thread is wearing
Stocker
That'll do it!  I think you actually need a very small amount of toe-in to make it track straight....
My goal in life is to be as a good a person as my dog already thinks I am.
If you don't learn something every day, you're not paying attention.
95yotakid
I dont know too much about this but it could also be balance issues too.
it is excessive toe out.. tire balance would have nothing to do with it unless it was cupped
toyotacrawller
it is suppose to be toed in 1/16 to 1/8 in  and it will start wearing good
Cheesemaker
