Steering arm bolts
Started by Blanco, March 08, 2009, 01:23:10 PM
Blanco
I just got some steering arms But dont have the bolts to bolt them to my '84 Toy axle.
& I was wondering are they plain simple bolts I can buy at the hardware store? or do they require some thing special?
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
bhigdon101
are they hi-steer arms?
if so i would get the dana 44 stud kit from mikeparts.com
cheapest around,that i know of...
and go a head and do the 5th stud too....
that is my 2 cents worth..
brian higdon...
daddy always said "if your going to be stupid, you better be tough"
zippo
If anything i would make sure they are Grade 8.8!
If you see it, its for sale.
dirtchicken
DO NOT use bolts on your steering arms. You need studs and cone washers to achieve proper clamping force on the arms. I'd personally go with FROR ARP studs for that application.
Blanco
OK I just realized That I did have the studs. Doh!
But I'm missing the washers & nuts.
Where do I get Cone washers? (lowes? Osh?)
& should I run Ny-locks?
boggerunner
do u need all 8 cone washers?
ive got
8 cone washers
8 washers
8 nuts
all stock parts i'll sell u for $15 shipped.
Blanco
Yes, I need all 8.
All I have are the studs..
Blanco
Might you have the shims that go under the steering arms as well?
I saw exploded view that show 3 shims per side & I only have one per side.
boggerunner
i only have one per side too, it depends on what u need to center the birf. i just used what was in there from the factory, there is a tool from toyota that is impossible to get that helps center it
Blanco
So your running one per side with no issues?
& where might I find the shims if I need more?
boggerunner
Blanco
I did'nt think they have that old stuff at a dealership still?
PM me your info So you can ship me those nuts & cone washers etc..
