Swap questions / sm465 35spline to toy mini case
Started by ITS PAT, March 07, 2009, 03:25:11 PM
ITS PAT
I did some searchs and saw its possible to run a toyota mini truck transfer case behind a SM465 trans but im still confused after reading about a couple things. Can you use the 2wd SM465 35 spline trans? I have a TBI 350 with all the wiring computer ect I want to put in my 1984 extra cab. I plan on doing firewall and tunnel mods to move it back and not use a body lift. If the 35 spline output cant be used can a 10 spline 4x4 shaft be installed in the 2wd transmission?
TIN BENDERS
