fj60 axle questions
Started by yjay, March 07, 2009, 12:52:37 PM
yjay
Are fj60(like the one pictured) rear axles the same as v6 ones? Are the front axles the same as 1st gen truck stuff and/or a good candidate for sas ? Is the width correct?
Thanx
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
dniel
The fronts are the similar to a mini. The main difference is it has a 9.5" ring gear. It is also about 3" wider. The outers are the same as a mini.
The rear is offset and would not work well for a mini truck.
1uz-fe, 1 tons, 44" tsl
yjay
Are the fronts preferable then to a 8"? The reason I'm asking is because I found some cheap.Also wondering about aftermarket.
22re Daily Driver
dniel
Quote from: yjay on March 07, 2009, 05:59:12 PM
My brother is thinking about using one. The ring and pinion would be much stronger than a mini and you can use 30 spline longs in them. You can get 4.88 and 5.29 gears and lockers for them. They are also 58.5" wide and would match an ifs rear without spacers. Before you buy do research on fine and coarse spline pinions. You want the fine spline ones which came in later models. Ih8mud.com is a good cruiser site.
These axles are very cheap were I live. If the set you're looking at is fine spline run the front and keep the third from the rear for a spare as it is the same as the front.
yjay
22re Daily Driver
Hammerhead
FJ60 front axle is good for SAS and the offset rear can be hybridized with toy-mini axles to make a matching rear...  :yesnod:
'82 pickup, +3, locked, doubled
'82 pickup, IFS long travel, V8
'85 4runner, V8 rock crawler
'88 X-cab, V6
Hammerhead
'88 X-cab, V6
twistedtoy92
