Author Topic: 4.88 gear question  (Read 3449 times)
ezthere
  • Turtle Points: -11
  • Member since Feb '04
  • 85 4runner, worked 4.3L V6. 300HP.
4.88 gear question
« on: Sep 26, 2004, 01:01:05 AM »
I was told that 4.88's come equiped in 1978 and 1979 toyota trucks..Is this true  :dunno:
Chuck
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re: 4.88 gear question
« Reply #1 on: Sep 26, 2004, 01:23:48 AM »
4.38's were common but Im not aware of any that came factory with 4.88's.
  • Administrator
  • Turtle Points: 2205
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #2 on: Sep 26, 2004, 01:24:10 AM »
no way jose
no such thing as a '78 4WD pickup and all 4 speeds came with 3.xx something, like 3.90 I forgot :smack:
« Reply #3 on: Sep 26, 2004, 01:26:51 AM »
yup 3.90's in the 4 speed trucks. :gap:
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: Sep 26, 2004, 03:57:52 AM »
hmm can you explain then the factory code for my truck,,,,,,,L-43 G102  :slap:
it is "possible"  that one or two might have been ordered from the factory as 3/4 tons with 4.88 gears,  never seen it but its possible,  ive seen 4 so far that had the 4.375 r&p code, G102 with the L43  they were all early year, as in 2-79 model short beds,   80 models as far as i can tell and "most" 79 all had 3.90 gears,  think it was a G072 code
if it has a G142  then its a 4.88 a.k.a.  3/4 ton
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
  • Member since Oct '03
« Reply #5 on: Sep 26, 2004, 06:31:53 AM »
I heard that 3.90s will do quite nicely with the new 52 inch tires.
  • Administrator
  • 511:1 Club
« Reply #6 on: Sep 26, 2004, 08:31:20 AM »
:funny:
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
« Reply #7 on: Sep 26, 2004, 09:58:24 AM »
Yeah White Trash's truck really hauls ass down hill in fifth!!
« Reply #8 on: Sep 26, 2004, 02:40:12 PM »
Yea yea you guys suck lol.  Ive got the only W56 3 speed with overdrive and warp speed! :gap:
lowgeared
  • Turtle Points: -1
  • Male Posts: 556
« Reply #9 on: Sep 26, 2004, 03:48:32 PM »
I've got to get one of those!   :driving:
ezthere [OP]
« Reply #10 on: Sep 26, 2004, 04:43:31 PM »
http://home.4x4wire.com/erik/diffs/#rear
4cyl Turbo and V6* 4Runners and mini-trucks use the Toyota 8" 4-pinion differential in the rear. This diff is known as the "V6/Turbo diff." It has larger carrier bearings, is generally stronger than the standard 4cyl version, and is a direct swap into axles that use the 4cyl 8" diff. Separate gear sets are made for the V6 style diff (only from Toyota and Precision Gear), but cheaper, more readily available 4cyl style gears are commonly made to fit- the only difference being a very slightly larger pinion gear on the V6 style gear (the actual strength difference in gear sets is debatable). The strength increase in this diff over the 4cyl diff comes mainly from the beefed up housing, which stiffens the entire assembly, keeping the gears in proper (stronger) alignment.
Although somewhat rare, there is a version of this diff that came from the factory with  :psss:  4.88 gears.  The carrier (3rd member housing) has a different pinion offset so that the ring gear doesn't need to be as thick.  This means that no gears other than the factory 4.88's will fit this particular diff. However, diff cases, commonly called carriers (factory, LSD, lockers, etc.), for the standard V6/Turbo diff should be interchangeable (4cyl and V6/Turbo carriers are NOT interchangeable).
* A few V6 trucks and 4runners have been found to have come with the 4cyl style diff from the factory. Nobody knows why.
Chuck
Last post Mar 23, 2005, 03:17:29 PM
by kpagel
Last post Aug 29, 2005, 12:01:19 PM
by blackdiamond
Last post Sep 08, 2005, 08:18:40 PM
by mudmaster
Last post Oct 07, 2010, 11:26:12 AM
by MAD MARK
Last post Apr 25, 2016, 07:29:42 PM
by Bent 85
