Author Topic: cone washers  (Read 2225 times)
87yoter
  • Turtle Points: -5
  • Male Posts: 71
  • Member since Feb '09
  • Makes Me Feel So Good!
cone washers
« on: Mar 03, 2009, 10:41:50 AM »
I have my own preferences on how to take them out, but ive heard a thousand different ways. just curious about some different methods
get it!
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
Re: cone washers
« Reply #1 on: Mar 03, 2009, 11:38:46 AM »
I have a small standard screwdriver that I use to tap into the slot of the cones to spread them open enough to get them to release off the studs, works every time.  never had to beat on a hub body or stud
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • Member since Mar '07
  • 1St Gens Rule!
Re: cone washers
« Reply #2 on: Mar 03, 2009, 11:56:36 AM »
Brass drift on the end of the stud and a big hammer
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
vincesyota
Re: cone washers
« Reply #3 on: Mar 03, 2009, 03:51:55 PM »
 I have a Brass hammer and just smack the top of the stud
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: cone washers
« Reply #4 on: Mar 03, 2009, 05:09:59 PM »
I have always hit next to the washer, not the stud.  I dont see hitting the stud.  I have never had a problem. So School me.  I would hit the stud to break a rust problem, but for a cone washer issue    :headscratch:  I advise, once they are off, put some sorta lube on them, before you re-install.  :twocents:
Toymin8r
  • Turtle Points: 50
  • Male Posts: 929
  • Member since Dec '07
Re: cone washers
« Reply #5 on: Mar 03, 2009, 05:11:35 PM »
X2 This way works every time.  :thumbs:
Quote
brainlessfool
  • Turtle Points: 2730
  • Male Posts: 4,207
  • Member since Jun '02
    • Buy me a cigar
Re: cone washers
« Reply #6 on: Mar 03, 2009, 05:40:37 PM »
I just heat the whole knuckle till it's glows red and hit it with a BFH.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: cone washers
« Reply #7 on: Mar 03, 2009, 07:39:28 PM »
I use a hammer :gap:
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
Re: cone washers
« Reply #8 on: Mar 03, 2009, 07:55:22 PM »
I pretty much use a combination of all those (except heat....which I had to use once when there was water frozen inside my steering arm hole)
anti-seize (ALWAYS)
brass punch
BFH
small screwdriver in the slot
works every time....i could do it in my sleep (time for longs) :gap:
Quote
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
Re: cone washers
« Reply #9 on: Mar 03, 2009, 07:59:33 PM »
wait...what kinda cone washers u talking about?
steering arm cones and hub cones are two different animals!
Quote
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
Re: cone washers
« Reply #10 on: Mar 03, 2009, 08:03:21 PM »
thats what I was wondering.... my steering arms have always came off pretty easy... hubs on the other hand I use the screwdriver in the slot trick and it works great every time! :yupyup:
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • 1St Gens Rule!
Re: cone washers
« Reply #11 on: Mar 04, 2009, 07:58:22 AM »
I use the same method for the knuckle cones and the hub cones.   :burnout:
87yoter [OP]
  • Turtle Points: -5
  • Male Posts: 71
Re: cone washers
« Reply #12 on: Mar 04, 2009, 09:59:46 AM »
i was talkin hubs. best trick ive found is brass drift on the outside of the hub body makin sure you got your finger over the end of the stud or a nut or something cause I shot my first one out into the yard and had to go rob one
get it!
Last post May 23, 2004, 10:46:39 PM
by hawaii500_1999
Last post Jan 08, 2006, 05:25:35 AM
by Willy Mammoth
Last post Aug 31, 2007, 11:17:02 AM
by toyo487
Last post Mar 27, 2009, 06:48:33 AM
by Glen1978
Last post Jun 25, 2009, 10:45:58 AM
by DaveZ
