FJ 40 Rear springs with bolt in center (not stock position
Started by jerz4wd, September 23, 2004, 01:12:47 PM
jerz4wd
Does anyone make a rear leaf spring that has the centering bolt located in the middle of the spring?? I swapped my spring end for end and it helped with driveline length but,,,, my rear gas tank has a problem when I'm fully loaded in that it wants to hit the rearend. I'm sure someone out there has probably heard of this before. :smack:
thanks for the site!! Jerz4wd
Central Valley Crawlers
4X 4him
They make relocation plates that move the axle an inch or so in either direction.  Depending on how much you need your axle moved it may work.
