GM alts
Started by toyman2, September 18, 2004, 08:37:48 PM
toyman2
ok ive done alot of reading now what i need is to know exacely how to wire it in im going to go get a GM 213-4711 alt tomarrowi guess thats the 120 amp witch will work just fine
i have about had it with all my charging problems
i have a 80 pu so mabey some pictures or diagrams to witch i didnt find when i searched
   it will be nice to be rid of this headach
freds40
Haven't done a "one wire" on a Toy but did it on earlier Chevys. I got a pigtail from NAPA that had a 5 ohm resistor on it with a hot lead. This plugs into the alternator and the hot lead just jumps to the power lug on the alternator. Then you run from the lug to your system, super simple. Oh BTW, with the new 5 ohm resistor, you need to remove the resistor inside the alternator, I think it's like 35 ohm. Worked great on my Chevelle.  :shocking:
"between projects"
You need a 213-4011 alternator to be easily compatible and mounted.  The 213-4711 is designed for a serpentine belt setup and has totally different mounting and plugs.  The 4011 is only a 65+ amp but its cheap and rather reliable.  I cant remember the pn#'s for the higher amp alternator in that series, but if memory serves get one for a 84 Camaro with a/c and power windows.  It should be 108 amp.
toyman2
65 amp isnt much of a up gradei think my toyota alt is 40-45 and when i run my headlights and
KC lights i wont keep up let alone my winch
Mike D
run a dual battery setup
toyman2
in set up for duel batts but i kept smokin alts
toyman2
i checked on the camaro alt and its a surp.belt drive if someone could scroung up a higher amp alt ## that would be great :help:
Mike D
this is a dirct fit alt that you can get up to 160 amps but they run at 468 bucks for the 160 http://www.northwestoffroad.com/parts/alternators.html
toyman2
if i was going to spend that kinda money and still have to do some changes id just go all the way and get a premier power welder set up thabks thow
i was thinking more of ahigher gm alt in the same series as what WT was saying
mabey someone can tell me why my brand new alt is charging intermitly
thought id throw it in
The alternator on my 84 is a big case gm, it came off of a 86ish Buick Regal.  Im not sure if there would be room for that big of an alt but its worth a shot.  The Camaro alternator will work fine as all that they changed ws the pulley.  The mounting is still the same as the usual alternators.  Get that and a vrc-148 and your set.
toyman2
supercrawler
#11
I have done it 2 years ago.
It's very simple all you need is 2wire GM ALT
http://www.oldengine.org/unfaq/10si.htm
Terminal#2 and BAT (jumper)goes to Batt +terminal
Terminal#1 goes to voltmeter
supercrawler
#12
Pic 2
Sorry it's 12si GM alter.
Wiring are same i had to rebuild it so on idle i got 80~100 amp which is more then enough for my use.
Voltage Regulator Connector #148Thats the Napa pn# for the plug youd need for the alternator.
kyle_22r
do those alts need a regulator?  i'd love to step up to an 80 or 100 amp alternator
my '79 has a regulator, i'd like to be able to ditch it and only want 2 wires( one for the battery, one for the idiot light).
Its internaly regulated.
toyman2
supercrawl witch alt are you running
and is there a higher out put smaller case  with a v-belt drive or is the 65 amp about it
i would guess it wouldnt cost to
much to have it rebuilt for more amps
  sorry guys  if im going to up grade i just want the best bang for the buck and i want to do it right
im sick of charging problems   thanks guys
supercrawler
#17
12SI is the best GM alter.(i believe mine came off from 89 chevy pick up truck)
It's compact yet can easlly upgrade to hi output AMPs (local alterator shop upgrade mine)
It's simple as far as wiring concern and pully is intercahanable with toy v-belt
There is site regarding about GM alter(i will post asap)
Hey! it's dirt cheap and GM alter very reliable,last forever,best of all there's ton of'um out there at junk yard.
Try to upgrade toy alter to  Hi amps you'll have to spend 300+  :(
I had spend 80.00 total with 100amps on idle.... not bad at all :)
toyman2
yea thats about what im looking for  the 12si whats the part numberor is that the one WT listed above
camo89
thw alt WT listed is the 65 amp virsion you can get off aney chevy i got the one for my old truck of a caddy it was like a damn citation but it was 135 amp and the same size as the one WT listed i dont have the part number but i got it from napa and it was like 75 bucks in stock
me
mopar parts
