wood turning lathe. can it be turned into a metal working....
Started by Bazzi, February 08, 2009, 03:25:24 PM
Bazzi
I was offered an old wood turning lathe... I don´t have much info on it, other than it has a few different speeds. I would have to fix it with some chuck and a cross/side transfer or what to call it.....
the question is is it worth the time and money or should I just wait a few years and wait till an old metal working lathe falls into my hands...
ideas?
brainlessfool
I have an old Sears wood lathe. and have used others. also have run metal lathes. ( work and school)
my  :twocents: can't change wood to metal. no way.
Bazzi
I googled it and so on... it has been done. but I have doubts it´s worth it? am hoping I am wrong
brainlessfool
Bazzi
do you know the feeling when you are working on something and it would all be soo much simplier if you have something you normally have access to....
.... I don´t know.. making seats for bushings... and stuff like that. I need to make aliment tools for the housing I am gonna make.  :crossed: those would be made out of plastic, just so it fits in the 3rd member so I can run an axle through the housing to  have it straight.... I bet if I can fit an cross slide to that lathe I can make that... I am just wondering if that´s all I will use that lathe. if so  it´s not worth the time.
NorCalToy
How much will it cost you to get teh wood lathe? if its cheap or free, might as well give it a shot, if it doesnt work,your back to where you are now. :twocents:
:flamer: IFS
Cheesemaker
No, it shouldn't be used.  If you look at a wood lathe and then a metal lathe, you will notice that the metal lathe is really heavy and beef!  And then you would have to fabricate the cutting head.  You would be better buying a lathe that was designed for metal.  Get all your buddies to pitch in on a community lathe?  That way you don't only use it a few times a year, and it will pay for it self in short time.
abnormaltoy
Quote from: Bazzi on February 08, 2009, 04:13:51 PM
Just because something has been done, doesn't mean in was done well.
You can turn almost anything into almost anything else...but, you may also be turning something into a turd (an unsafe turd at that).
Cheese is right the heft and precision of a metal lathe just isn't built into a wood lathe.
Don't do it...but, if you do, take a video so we can see the carnage.
-- Winston Churchill
Travis Tritt (I know!)
Bazzi
Hey... where´s the faith :qtip:
I looked at the lathe today, and basicly it´s a wood lath. hmm I don´t belive I have ever seen one of those before.   basicly I have a land and a motor. I would have to make ewerything else..... it is defenetly a challenge. I guess I´ll just have to wait some more :down:
Plekto
Note - though, you could use a metal lathe for stuff like wood in a pinch.  Also tons of other things in a pinch, I wager.  But the opposite?  Um... metal is a *tad* harder than wood last I checked.   Heh.
http://lumberjocks.com/topics/3647
Small discussion on the differences.  The big one is that a metal lathe typically has a fixed/mechanically held cutter.  I can't imagine trying to cut metal by hand in a wood lathe without really bad things(tm) happening.  One small mistake and the tool is going to fly - or pieces will chip off - at high speed.
IronClad
oh my goodness someone wants to do somthing out of the box ! shun shun shun!  Try it man if anything you will learn somthing along the way and that is always good.
Annihilation  Fabrication
Do you need a Hammer?
Bazzi
the main difference between wood and metal lathe is that the wood one doesn´t have a chuck that holds it in place... the wood is only held in place with 1 spike thingy at each end. and you don´t have a cross cutting thingy either. you have some hand tools that you use to feel the wood down....
as I was saying there is a way to much difference to give it a much thought. but  if you think about it if you find yourself with the oppertunity of a free chuck. a free tool/crossfeeder thingy and a free wood turning lathe then you are a huge pruuuuude if you don´t think 2x about that. I have a free wood lathe on my hands, as I was saying after I took a look at the lathe, it´s basicly a motor and a land. it´s probably not worth the drive down there to pick it up 10 minutes....
so  have some coffe and have a good day
abnormaltoy
Quote from: Bazzi on February 10, 2009, 12:29:47 AM
:rofl2: I love a good technical explanation to start my day!
