Order the large bushings from Marlin
I'm in the middle of a similar swap and I know that lexus body harness is a huge rats nest. There are two of them actually. and about 10 differnt computers for variouse things.
Only one of the original bolts lines up but you can bolt the Lexus column to that and it makes lining up the other 3 much easier. I'm using the Lexus body harness so it's easier to use the Lexus column since it has the ignition and cruise control built into it. Plus it adjusts electrically up and down as well in and out. Supposedly when you turn off the engine and pull out the key the column automatically retracts and moves up out of your way. 8)
You only need about half of it. I might strip mine down or I might just stuff it behind the the dash and forget about it. I like the way the Lexus harness unplugs into smaller parts. Try to document your build as much as possible. When a few people have completed this swap we should make a thread like they have for the 3rz.Have you decided how you are going to control your fuel pump?
I am documenting it. I was just gonna wait until it was running before putting together a build thread. There are several 1uz swap threads that have been floating around for years and never fininshed and it really irritated me.
Any teaser pics.
wow, this is a great build. I have a buddy w/ a wrecked sc400 that I've been really tempted to pick up for my truck. Would you have to modify the front sheetmetal like you did, or was that just because of the massive forward shift you did on the front axle?
can you even mate any 5speed to the 1uz? lol
Yes. There are several different ways. There is even a factory application that is supposed to work. The problem, like I said is that all the options are quite expensive.
I remember Castlemain Rod Shop being the one I found on a search, but it's in Australia too
I am just wondering if there is any factory 5speed that the bellhousing will just bolt up.curiousty killed the cat
Started by freds40 Parts For Sale
Started by iNfErNaL Parts For Sale
Started by WHITE RHINO Parts For Sale
Started by BoG-ToY Tire and Wheel Tech
