higth ideal after motor swap
Started by greenjacob, December 16, 2008, 09:17:20 PM
greenjacob
just bougth a new truck with 22re that nocked swaped motors today and now it ideals at 3k or so and jumps up and down idk what to do
1986 4runner 93 22re 5.29s locked f/r duals twin sticks 39.5s
Toymin8r
Quote from: greenjacob on December 16, 2008, 09:17:20 PM
What in the world did you just say????   :headscratch:
greenjacob
3 days ago my efi worked great put a new motor in now it ideals at 3k and sures up and down after it gets hot
greenjacob
greenjacob
ninja turtle
      dude... i cant spell for :pokinit: either but thats what "spell check" is for. its hard for people to help you if they cant understand what the hell your saying, know what i mean? also, we need a lot more info on your truck and the new motor. if you did this swap im sure you can fix this problem.
  http://board.marlincrawler.com/index.php?topic=19277.0
start here. do some reading, there is a ton of info on 22re's.   :beerchug:
Quote from: greenjacob on December 16, 2008, 09:43:57 PM
:headscratch: you mean it "idles" at 3000 rpms??
have no idea what a "sures" is  :eek:
Rockcrawlintoy
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
AaronB
I just bought a new truck with a 22re that knocked. I swapped motors today and now it idles at 3k and jumps up and down. i dont know what to do!
Duffil
start by checking to see if it throws a code when you jump the terminals. You probably missed a connection or something.
93tonkatoy
Sounds like a vacuum leak. Check all of your vacuum lines and the EGR connections (where it bolts to the intake plenum, and the compression nut just below it). The compression nut on the pipe going from the ERG valve to the intake was the problem with mine.
SAVE TELLICO post 491
Cheesemaker
Get yourself a FSM!  That is your friend.
