you can rebuild it fine, everybody is scared of them because they have headgasket problems, did you drain the coolant or something and maybe didnt get it completely full or did it just start "disappearing"
Won't a bad cap still pull fluid back from the reservoir. 1) Get it hot and check for leaks. 2) Take it to shop and pressure test the system/cap/cylinders.You should stop driving this truck as a bad headgasket could lead to motor failure. I had a gasket go on me, and it sucked all the coolant through the motor, then cooked the motor.
Started by leorn Parts Wanted
Started by AJ Parts Wanted
Started by weirdtimes_7 « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by JoeWelder Toyota Pickup/4Runner Tech 1979-95
Started by Dirt Mover Toyota Pickup/4Runner Tech 1979-95
