Marlin, question about flat towing for you.
Started by Lowrider, December 15, 2008, 01:31:58 PM
Lowrider
Ok Marlin, I know that the rear shaft should be pulled, but humor me here please.  :greengrin:
Flat towing with a twin stick.
Trans in fourth.
T-case left side in nuetral.
T-case right side in 2wd.
The front driveline should not spin, but is everything getting lubed properly in the t-case?
:dunno:
www.YotaMasters.com
Lowered Headlights & Disco Lights!
AaronB
as far as Ive heard everything should be in neutral
BLACKDOG
              -Ronald Reagan
Lowrider
Negative ghost riders. Marlin can confirm that the factory owners manual says to put the t-case in nuetral, and the trans in fourth. The question I was asking Marlin, is with a TWIN STICK, if you put the left stick in nuetral, and the right stick in 2wd, do you end up with a situation where the front driveshaft does not turn, and the T-case lubricating itself?
www.YotaMasters.com
