Damn Fuse
Started by jrpitdog, August 27, 2004, 07:29:43 PM
jrpitdog
I have a 92 4runner the other day it just died so I fugured it was a fuse because there was no chugging when it died it just stopped. Well I was right it ended up being the 30A EFI/Ignition fusible link, Well I cant find the problem the engine still turns over and the battery works but as soon as I put a new fuse in it blows. So any suggestions or Ideas would be appreciated thanks.
Thumper
I did the same thing you are talking about on my 95 runner with the 3.0 v6 i was going too run a code check and accidently jumped the wrong 2 things and bam just quit and blew the 30 amp fuse but i just put in a new one and its fine but i would check for loose or broken or stipped wires that could be going too ground sounds like u have a dead short.
Sorry i can help more but someone on here can i bet.
good luck
adam
Marlin
You have a short :help:
Begin by getting a factory service manual and tracing the EFI/Ignition circut.
Do you have an after market alarm? This is a very common problem.
You are going to have to spend time, and find the damn short.
Good luck, Marlin
OFFRODN
 I had something close to that happen to my 85. as it turned out it was the wire that mounts on top of the alt it was touching the housing. hope that helps
yotaboy79
short i got those all over in my truck fixed most of them its been a wile sence i blew  a fuse im amased now that ive sead that ill prolly blow a fuze good luck finding the short
