Author Topic: Tacoma Idle  (Read 3470 times)
Dark Chaos
  • Guest
  • Marlin Crawler
  • I used to Crawl. I still do, but I used to, too.
Tacoma Idle
« on: Aug 26, 2004, 02:15:46 PM »
I own a 2000 Tacoma reg cab :mad: when I am in first gear letting my truck idle along at about 800 rpms then all of a sudden it starts speeding up by its self up to 1500 rpms then back down. :mad: I was reading were the 2000 EFI systems there is nothing to adjust it is either that the fuel injectors could be dirty or malfunctioning? Experienced Toy mechs please help.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
Re: Tacoma Idle
« Reply #1 on: Aug 29, 2004, 09:36:02 PM »
After you have checked for loose air intake fittings and/or vacume leaks--
The most common problem is a dirty/fouled air flow sensor that is sending a false signal. It is mounted on the air cleaner housing and secured by two screws.
Unplug the wiring harness, and then remove the sensor. I have had some success cleaning the sensor with brake clean and then lighty blowing it off with compressed air.
If all else fails, do it right and install a new sensor :driving:
After market, open element air cleaners are know for causing problems with the air flow sensor.
Marlin
Dark Chaos
  • Guest
  • Marlin Crawler
Re: Tacoma Idle
« Reply #2 on: Sep 02, 2004, 09:28:02 AM »
I checked all my hoses they are tight and free of dry rot I am going to go to the part store to pick up some cleaner then I will tell you my results.
SWAMPER
  • Turtle Points: 790
  • Male Posts: 3,599
  • Member since May '04
  • Semper Fi
Re: Tacoma Idle
« Reply #3 on: Sep 02, 2004, 10:09:53 AM »
Same thing happens to me but I own a 94 3.0 V6 Runner :dunno: I will try Marlins trick and tell you guys if that helps :thumbs:
SWAMPER
  • Male Posts: 3,599
  • Semper Fi
Re: Tacoma Idle
« Reply #4 on: Sep 04, 2004, 11:53:23 AM »
I dint get to try Marlins trick because my truck was in the shop and they replaced the Idler pulley and that fixed it :beerchug:
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
Re: Tacoma Idle
« Reply #5 on: Sep 04, 2004, 07:40:00 PM »
check the tps (throttle positioning sensor)
Last post Nov 14, 2003, 10:51:00 AM
by 95TacoTruck
Last post Mar 11, 2004, 03:29:38 PM
by max
Last post Mar 04, 2004, 10:28:34 AM
by 84runner
Last post May 27, 2004, 08:05:18 PM
by grumpy1@netptc.net
Last post May 20, 2010, 07:05:06 AM
by crawler92
