Author Topic: OIL LEAK 22RE  (Read 6982 times)
yotatough
  • Turtle Points: 16
  • Member since Oct '06
OIL LEAK 22RE
« on: Nov 22, 2008, 02:08:46 PM »
this same motor http://board.marlincrawler.com/index.php?topic=51451.0
ok I was thinking it could be the timing chain hitting the cover but I have never heard what that sounds like before so I'm still not sure.
Anyway here it is,  I was on my way home from Lemore yesterday ( thats about 45 miles out of fresno ) and I left it in gear a little longer than normaly wile taking off ( maybe over rev? ) and I was pushing it a little harder than usually ( Friday trying to get home ). I started to smell a little bit of oil burning, I thought it was just getting a litttle hotter than normal. ran fine all the way home, got home unloaded and noticed oil on the ground all over and covering the bottom of the truck from front to back. it made a huge mess.
so this morning I pressure washed it all, and now I cant see where its coming from but its the drivers front of motor and leaking down onto lower radiator hose. I havent yet started to take it apart to get a better look but was wondering if its the cover leaking do to the chain hitting it where dose it normally rub a hole? drivers side or pass? and can anyone explain what it sounds like when the guides are bad?
thanks everyone in advance  :beerchug:
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: OIL LEAK 22RE
« Reply #1 on: Nov 22, 2008, 03:05:23 PM »
Front Oil Seal..........
Get a replacement from Toyota, others start to leak again really soon.
Can be replaced with engine and oil pump in truck.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Prismo
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
Re: OIL LEAK 22RE
« Reply #2 on: Nov 22, 2008, 03:34:49 PM »
To answer your question it rubs on the drivers side. Usually wears into the water passage & leaks water into the oil. Does not usually cause the cover to leak oil to the outside of the engine. It will cause it to rattle like a diesel when the guides are broken.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: OIL LEAK 22RE
« Reply #3 on: Nov 22, 2008, 07:08:33 PM »
My 4Runner wore a hole on the cover outside of the pump housing, spit oil all over the front and under the truck like you described. Like said in an earlier post kinda sounds like a diesel rattle.
SolidAxle
  • Turtle Points: 6
  • Male Posts: 365
  • Member since Oct '05
  • My truck is 5 years older than me
Re: OIL LEAK 22RE
« Reply #4 on: Nov 22, 2008, 08:13:56 PM »
diesel noise not to be confused with the tappety valves lol. My buddies timing chain sounds like death when he starts it. It really sounds like a bicycle chain being dragged over the timing cover. it usually gets more nasty when you rev the engine higher and is almost silent at idle.
If your engine is clean now start it up and let it idle or take it on a quick drive so some oil will begin to leak that way you can trace it.
yotatough [OP]
  • Turtle Points: 16
Re: OIL LEAK 22RE
« Reply #5 on: Nov 24, 2008, 05:46:27 PM »
Yeah it is the oil seal,
I just called ENGNBLDR and ordered a timing chain kit ( with metal guides ) timing cover, oil pump, cam shaft, and upper gasket kit.   so this weekend I will be tearing into it.   I feel like a little kid waiting for santa  ( santa drives a brown truck )
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
Re: OIL LEAK 22RE
« Reply #6 on: Nov 24, 2008, 06:07:30 PM »
you can get the exact same thing they are gonna send you from EB at sebring west, here in fresno :twocents:
Prismo
Re: OIL LEAK 22RE
« Reply #7 on: Nov 24, 2008, 06:50:44 PM »
If there is a groove worn into the crank where the seal rides the new seal may leak. If that is the case you can buy a redisleeve or speedisleeve from NAPA . Looks something like this
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
Re: OIL LEAK 22RE
« Reply #8 on: Nov 24, 2008, 06:54:57 PM »
I believe the new replacement seals aren't as thick as the original (depending on year).....
You can then position the replacement seal in the oil pump (vary the depth insertion) so the lip isn't in the groove and you'll be fine.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
bkubisht
  • Turtle Points: -1
  • Member since May '05
  • Just crawling around
Re: OIL LEAK 22RE
« Reply #9 on: Nov 29, 2008, 08:04:09 PM »
That's what I was thinking...
http://home.earthlink.net/~twopapa/toytech.htm#seal
Last post Oct 11, 2004, 05:18:22 PM
by Mike D
Last post Jun 03, 2006, 09:21:32 PM
by zorack86
Last post Dec 04, 2007, 08:51:29 PM
by Plekto
Last post Mar 22, 2011, 07:34:50 PM
by oldblue
Last post Oct 30, 2012, 10:28:38 AM
by Fisch_Taco
