Author Topic: vibes with flat belly  (Read 3906 times)
toyotaboy
  • Turtle Points: 238
  • Member since Sep '02
« on: Nov 11, 2008, 10:26:39 PM »
so i got bored and cut my floor up for the flat belly.... im curious how many of you run a flat belly on and dd on the road... im curious if it will behave well going 70-75 down the freeway with the tcase output that high up there... no i am not going to lift my engine....
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
Re: vibes with flat belly
« Reply #1 on: Nov 12, 2008, 08:33:11 AM »
lifting the rear of the tcase that much  will be just like lifting the truck that much as far as the rear shaft is concerned
i would think it would definetly vibe but :dunno:
maybe drop it a inch :dunno:
Talon84x4
  • Turtle Points: 375
  • Male Posts: 919
  • Member since Mar '06
« Reply #2 on: Nov 12, 2008, 09:40:01 AM »
Lifting the motor with make for a better angle at the rear of the case, but you said you didn't want to do that... :dunno:
Do you have a CV on the rear driveline?
Central Valley Crawlers
  • Turtle Points: 1174
  • Male Posts: 5,060
  • Crawlin with Marlin
« Reply #3 on: Nov 12, 2008, 12:00:36 PM »
The problem I see is that the rear output on the transer case will be angled slightly up.  This will required additional angles of operation for the u-joint.  It looks like you have an extended cab so you may have a long enough wheel base to make it work.  The more angle in the u-joint the faster they wear.  Also, you won't be able to match the pinion flange angle so you'll need a CV style shaft.
I don't consider a flat belly a DD type of mod, but I'm sure it can be done.  :thumbs:
TheCookieMonster
  • Male Posts: 973
  • Member since Dec '07
« Reply #4 on: Nov 12, 2008, 12:17:46 PM »
mines flatbellied but i dont dd it...you will definetly have more vibrations if your solid mounting your crossmember to the frame...ever since i did mine ive had interesting noises coming from the tranny and t-cases. i added a little more gear oil to the tranny and t-cases and it seemed to help a little. im not sure if its an oiling issue or what??  im also not running cv's at all front or rear so those might help with the vibs too. im not sure if i would go completly flat with the frame if your dd it, and if you dont want to lift your motor mounts.
let me tell you it will help out if you do a lot of rock crawling  :beerchug:  :twocents:
  • Male Posts: 5,060
« Reply #5 on: Nov 12, 2008, 12:24:30 PM »
Are you saying that you eliminated the rubber mount that goes between the t-case and cross-member?  If so, I would expect a horrible amount of vibrations as it would be similar to eliminating the rubber mounts on the exhaust.
TheCookieMonster
  • Male Posts: 973
« Reply #6 on: Nov 12, 2008, 12:33:26 PM »
yep i made a whole new crossmember with spring bushings instead of the stock rubber mounts..it vibrates but it not that bad...if you got a lot of stuff in the glove box it gets kinda annoying.
edit: here's a pic
toyotaboy [OP]
« Reply #7 on: Nov 12, 2008, 05:55:37 PM »
i do have a tacoma to dd but i also want to cruz this thing around and i hate vibrations.... plan on making a crossmember essentially just like that one... thats how i had it visualized almost  to a t haha
rest in peace Effay
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #8 on: Nov 12, 2008, 06:24:02 PM »
it will be fine.  Yota4life drive his on the road and it is a short bed single cab with a flat belly.
toyotaboy [OP]
« Reply #9 on: Nov 12, 2008, 06:25:44 PM »
right on.... ill figure it out and make it work.... or have some vibes :)
rest in peace Effay
Last post Jun 28, 2006, 07:00:04 PM
by MR_DIY
Last post Jan 18, 2007, 08:39:13 PM
by Yota4life
Last post Feb 05, 2007, 08:57:46 PM
by Tice
Last post Feb 19, 2009, 11:50:53 AM
by TheCookieMonster
Last post Apr 09, 2021, 04:08:00 PM
by Draggingdiff
