Toy 8" axle weight?
Started by Mike D, August 23, 2004, 07:03:15 PM
Mike D
Does any body know how much it weighs? :dunno:
Skinny_Pedal
Im an OG
A shaft, the whole assembly, front or rear?
2 people could pick them up.
Skinny_Pedal
well i havent pickep up a 8" yet but my buddy and i pulled a 7.5" out of a 2wd and it required both of us and we were swearing while doing it!
Im an OG
brainlessfool
where the springs still on?  ???
Skinny_Pedal
Im an OG
brainlessfool
ok , you had me thinking that you guys are     :stopit:
                           :laugh: :hahaha: :laugh: :hahaha:  :wave:
       j/k    :smack:
To The Floor
I'd say it's probably 250-300 pounds.
brainlessfool
geee, I was thinking with out springs and drums more like 150-175 lbs
Skinny_Pedal
ttf was the other guy when we pulled that dam axle out!
Im an OG
That explains why it took both of you.
SWAMPER
 :laugh:
Yeah I was thinking the same thing  :beerchug:
To The Floor
Well I wasn't thinking about that time.  I was thinking about my '85 front axle.  but i didn't realize you were talking about the rear.
C'mon, i pulled a complete front axle into my garage about 20 feet by myself.  Although i did drag it.  Then i took it apart and it didn't weigh as much.     :sly:
To The Floor
Well yeah I lifted it onto a dolly by myself.  But it took my dad and I to get it out of the back of the truck
Mike D
Yeah i was wondering the weight of an 85 front axle cause the guy who is shipping it to me doesn't know how to weigh it.
I wanna say that complete its about 250-300.
88runner
I would say rear is less then 200 front should be aprox. 150 more
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
GrimReaper
Quote from: TTF Fabrication on August 23, 2004, 08:36:01 PM
You got to be kidding. The 12 bolt housing under my K5 is only 75lb empty. I can handle the axle by myself without hte drums so it can't be over 150. Surely the toy 8 inch cant be heavier then the GM cast iron center 8.75.
You boys need to go get some wheaties.
88runner
Quote from: GrimReaper on August 24, 2004, 10:44:56 AM
empty it's probably like 30 we're talking complete axle not just housing.
88 4runner v6,
solid axle'd
GrimReaper
Quote from: 88runner on August 24, 2004, 11:23:33 AM
I didin't type that out cealr. the GM with everything but drums is about 150#.
88runner
you're talking about the rear or the front?
toy front is in the neighbor of 300 and rear is less then 200 maybe like 150 with all on it.
cast iron doesn't weight as much as steel.
88 4runner v6,
solid axle'd
GrimReaper
Rear.
GM 10 bolt front is about 325-340 (abotu the same as a D44, D44 might be a little heavier, they use a little thincker tube). I can move it around one end at a time but way to much for me to get off the ground alone.  Now you want to talk heavy...D60 front is around 500lb. I helped move one of those around and MAN what a pig.
I just cant see a toy rear even with drums being much more then 150 range. Especialy with the 30lb empty housing figure up there.
GrimReaper
Quote from: 88runner on August 24, 2004, 11:41:05 AM
True if your talking about a 2x2x2 inch block but that cast iron center is THICK so the axle over all is heavier. Also the GM uses some thick pipe for the tubes. I know the shipping weight on empty housing is 75lb or so.
88runner
30 lbs was for the front without knuckel maybe more :dunno:
I'm not really a reference when come to weight, I moved my complete front axle allone for about 20 feet without dragin it,
had to take a day off after that but made it  :hahaha: :joke:
88 4runner v6,
solid axle'd
Caique Macedo
Hi
I have 2 in my garage, its about 270. the housing alone is about 70 and the third member is heavier than the housing.
i can measure the unassembly one if you really want
brainlessfool
I think we could use a REAL wight on this thing.  for the front LOADED, I vote for around 225-250
rotors, thrid ect. just no springs  :thumbs:
Mike D
yeah the whole front axle with no springs
If you really wanna know go to PBB and search for the post called    Ultimate toyota equipment weights.  4rnrick started the thread.
