92 2wd 22RE, 5 speed tranny????
Started by 4RnrRick, August 23, 2004, 10:51:35 AM
4RnrRick
I just collected a 92 2sd 22RE 5 speed tranny? Anybody know what this tranny is so I can get it advertised an dsold? looks like a W something to me......
Skinny_Pedal
Im an OG
toyotaboy
well if its 2wd are you sure its a w56... thats a 4wd tranny.....
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
Skinny_Pedal
to my understanding they could be either or. there was a w56 4wd and a w56 2wd. i could be talking out my ass though so who knows!
Im an OG
kyle_22r
i think 1 ton 2wds got the w56
count the splines on it, if it's 21 spline it's a w56, if 26 spline it's a G58(junk)
Marlin
#5
2WD trucks were available with the G or W series transmissions. Most EFI trucks got the W55, or W56 trans and after 88, I have never seen a G behind a 22R EFI motor.
The 2WD W56 will have a 3.83 first gear set that was never available in a 4WD truck :(
It is not uncommon to find a 2WD 3.83 gear set in a core 4WD trans from the large slam rebuilder companys :moon:
Count the center case bolts.
8 bolts  G trans
9 bolts  W trans
Both share the same bellhousing.
I have a number of 2WD W trans in stock. Due to the lighter drive train, they almost always will have a good reverse idler gear.
Marlin
4RnrRick
It has 21 splines and has 9 bolts on the center section.
So with that I'm assuming its a W55 or W56. Is they any way of knowing what it is for sure?
Also is there a market for these 2wd trannys because I need to get rid of it but I would like to get a little something for it.....
To The Floor
I was about to post and say it's most likely a W55, but Marlin took care of that  :bowdown:
4RnrRick
So how do I figure out which one it is?
Marlin
I will do some research in the Toyota fisch and see if I can find a differance.
I have not done enough of the 2WD trans to figure it out yet :dunno:
Marlin
4RnrRick
