Author Topic: how many shims to put on knuckle?  (Read 3547 times)
puunui
  • Male Posts: 35
  • Member since Mar '08
« on: Nov 04, 2008, 12:58:38 AM »
trying to finish my buddy's front end.he had to go to war.he was rebuilding it. he stop on putting knuckle arms back on. I greased up the steering bears. then I'm not to sure what shim size to start with? and not to clear on what and how to get bearing load? he got high steer knuckle arms. is the bearing load 4-5#?
Homefries
  • Male Posts: 241
  • Member since Apr '07
Re: how many shims to put on knuckle?
« Reply #1 on: Nov 04, 2008, 07:11:57 AM »
Start with one thick and one thin on top and bottom, preload should be around 12-15lbs.  If it is too loose remove one thin from the top if it is still too loose then remove a thin from the bottom but if you bought the kit from Marlin then it should be the one thin and one thick.   :beer:
bluetoy84
  • Turtle Points: -100
  • Male Posts: 300
  • Member since Jun '04
  • rice bouncer
« Reply #2 on: Nov 07, 2008, 10:47:37 AM »
It should be about .045" total per side. Usually a .040" and a .005".
puunui [OP]
  • Male Posts: 35
« Reply #3 on: Nov 23, 2008, 02:00:21 PM »
top and bottom .045
Ghtoyrunner
  • Male Posts: 117
  • Member since Nov '08
  • runna
« Reply #4 on: Jan 18, 2009, 12:46:06 PM »
if the nuckle preload is off would it make the truck have death wobble? i would assume if they were off the bears would wear out faster.
When in doubt throttle out!
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #5 on: Jan 18, 2009, 12:48:45 PM »
The knuckle preload is simply to tighten down the bearings on the knuckle like u said....the bearings would probably wear out quicker....if they wore out enough it could effect it......
Wheel bearings have more of an effct on death wobble
Quote
Ironloki
  • Turtle Points: -3
  • Male Posts: 87
  • Member since Dec '09
  • I cant drive 55.. literally.... its so slow
« Reply #6 on: May 19, 2010, 06:09:31 PM »
i wanted to know this. thank you.
If you stop evolving, you cease to exist.
Project bella👇
http://board.marlincrawler.com/index.php?topic=64106.0;highlight=bella
Last post May 09, 2007, 08:51:05 AM
by BoG-ToY
Last post Jul 08, 2007, 01:18:11 AM
by yotaboy79
Last post Aug 05, 2010, 12:12:31 AM
by luvyota
Last post Nov 30, 2012, 01:02:16 AM
by ValenciaTundra
Last post Apr 15, 2015, 05:34:21 PM
by jssgbsn
