95toyrunner "the rhino runner" now with 37" MT/r's!! need some help...
Started by 95toyrunner, November 02, 2008, 06:48:03 PM
95toyrunner
1995 toyota 4runner, sr5, 5" sas, ome 863 coils, extended links, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=51430.0 SOLD
1996 Toyota Tacoma ex-2wd, 2rz, 3link 14"FOAs, dual ultimate cases, chevy rear, 37" MT/r's, 4.88's
http://board.marlincrawler.com/index.php?topic=91724.0 SOLD
2001 Taco Dcab, king coilovers, 4.56 gears, detroit, 33's, SOLD
1999 Taco extracab, 3.4 5 speed, sas'd on one tons, 37" km2's, spooled front, detroit rear, bobbed, tirecarrier, hydro asist, high steer. SOLD
2005 4runner, sway-a-way coilovers, all pro rear 3.5 springs, 285 ko2's on method NVs SOLD
2016 4unner Trail, Icon stage 6, 285/75 Toyo's, full armor
88 4runner SAS, 37's, duals, etc
Joey88RUNR
88_Pathy
Why? It doesn't leave the pavement. ..... Oh yeah so its easier to get in. haha
95toyrunner
Quote from: 88_Pathy on December 06, 2009, 07:14:21 PM
very funny. i've had some front driveline issues but it'll be ready for the new years day bald run. yes it does need some sliders i know.
95toyrunner
1) i'm getting bad driveline vibes from the rear between 50 and 60mph whats going on? my pinion angle is ok, we did drop the driveshaft pretty hard once right on the splines and it has seen a little trail abuse. is it just off balance?
2) i'm getting wierd clunking/rattling from the front axle when i hit small bumps, brake, or turn. i just rebuilt it last weekend, new brakepads, everything is tight and i don't have any death wobbles and my shocks are brand new. i have no idea whats going on here...
bigarms23
does your rear shaft have alot of play? hows your u joints and i would have it balanced
95toyrunner
what do you mean by play? like if i grab it with my hands its a bit loose?
95toyrunner
Joey88RUNR
I had a vibration when i first did mine, which is what forced me to setup Duals and setup rear driveline with a dual cardan joint/Cv joint on the Tcase side of the shaft. You may have to much angle on the t-case side of the DL
Joey88RUNR
About the Rattle, Do your shocks have the sleeve in the bushing? See if the shock hoop or shock is contacting the inner fender, I have seen that before.
95toyrunner
my shocks do have sleeves in the bushings and the shock is contacting the fender well a bit. i'll take em out tomorrow and see if thats the problem.
89sastoyo
whats the specs on your front dl, square round? stock lengthend?
And for the rear my buddies truck gets the same vibe im sure from 65 and up. He just goes with it and I think it has something to do with his angle to the t case like that.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
