front shafts are over rated
If you don't mind me asking why did you choose to go with All Pro's biggest lift? What size tires are you planning on running? I know that they recommend running their front hanger with anything over their 4" lift kit (using 1.5" over stock shackles). Anything under you can scrape by without having to install it. If for some reason you can't do the dual cases i would say just drastically reduce the amount of lift.
bet you had fun getting those spring sin there w/o that front spring hanger ...
i take it you have never done a lift be for. why would they be any different than an aftermarket one then it wouldnt work. it wouldnt line up with the perches or shackles duhhhhhhhh
um BECAUSE, the lifted springs when about halfway compressed will bind because you didnt move the front hanger forward to compensate for the longer springs
my springs have no problem with bind at all. they flex all the way til it hit the body mounts. how would the front hanger move the springs forward when the springs are the same eye to eye as the stock ones? or i would had to relocate the front shackle hangers too. and whats with all the haters out there.
Started by CJTownsend Project Research and Build-Ups
Started by zr2runner « 1 2 » Toyota Pickup/4Runner Tech 1979-95
Started by 95runnerNW General 4WD Discussion
Started by 87pickup Engine
Started by clb Project Research and Build-Ups
