if you put your stock rear springs up front minus the helper spring and find some late 80s S10 2-wheel drive spings minus the helper in the rear, that will give you a nice and flexy 3-4 inch lift. that can all be found cheaply in your local junk yard
granted but its easy to make a new front crossmember for the hangers, even if you don't have the means to make one, you can find already made ones. a 110v mig of fluxcore welder can weld them to a yota frame and still provide enough penetration for it to be as strong as if you were to stick weld it. even if you don't use rears up front a desent lift would require either a new crossmeber or longer shackles
Started by sandboxtoy Parts Wanted
Started by toyotamobing Parts Wanted
Started by big ron Parts For Sale
Started by wannabe Suspension
