Author Topic: small lift  (Read 2420 times)
Toy Truck
  • Trade Count: (0)
  • Turtle Points: -5
  • Male Posts: 183
  • Member since Feb '08
small lift
« on: Oct 19, 2008, 09:15:12 AM »
anyone have a 2 or 3 inch lift for a 80 pu let me know
82fb
  • Trade Count: (0)
  • Member since Aug '05
Re: small lift
« Reply #1 on: Oct 19, 2008, 08:08:09 PM »
i have a set of front lift springs.  I think they used to be 4 inch springs, but they are probably 3 now, and I took out the very bottom leaf, so maybe 2 unless you put the bottom leaf from your existing pack in there.  They have poly bushings and are gonna cost you $20 for the pair if you want them.
mark
pm me
yotaofdoom11
  • Trade Count: (0)
  • Male Posts: 23
  • Member since Nov '07
  • Crushing Guts With Curtisy
Re: small lift
« Reply #2 on: Oct 29, 2008, 10:39:52 PM »
if you put your stock rear springs up front minus the helper spring and find some late 80s S10 2-wheel drive spings minus the helper in the rear, that will give you a nice and flexy 3-4 inch lift. that can all be found cheaply in your local junk yard
Crushing Guts With Curtissy
  • Trade Count: (0)
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: small lift
« Reply #3 on: Oct 29, 2008, 10:42:21 PM »
rears up front is not as easy as just bolting springs on.... that said, any quality lift will need modifcations to the truck to be made
yotaofdoom11
  • Trade Count: (0)
  • Male Posts: 23
Re: small lift
« Reply #4 on: Oct 30, 2008, 12:25:39 PM »
granted but its easy to make a new front crossmember for the hangers, even if you don't have the means to make one, you can find already made ones. :pokinit: a 110v mig of fluxcore welder can weld them to a yota frame and still provide enough penetration for it to be as strong as if you were to stick weld it. even if you don't use rears up front a desent lift would require either a new crossmeber or longer shackles
boggerunner
  • Trade Count: (0)
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
Re: small lift
« Reply #5 on: Nov 01, 2008, 10:30:53 PM »
i have a set of brand new 1.5 lift shackles front and rear with bolts $100
  • Trade Count: (0)
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: small lift
« Reply #6 on: Nov 30, 2008, 09:11:03 AM »
absolutely unnecessary,  and 2wd S10 springs wont swap right in without welding a new hanger in place,
I assume he wants a bolt in application,  i used 2wd S10 springs in my old suspension, it rode and handled GREAT and with the way i had them mixed with the stock springs they bolted right up to the stock location and gave me 3-3 1/2 inches of lift.
front and rear keep your top two leaves as they are, then put the 2wd S10 or ford F150 2wd individual leaves under them
here's a pic of my truck on this setup
Last post Sep 21, 2007, 06:45:19 PM
by 82juguete
Last post Nov 01, 2007, 12:23:37 AM
by Rocksnail
Last post Mar 20, 2008, 11:30:32 PM
by Knute
Last post Jan 20, 2010, 07:07:11 PM
by Aaronm
Last post Sep 27, 2014, 12:09:37 PM
by wing nut
