85 SR5 RUNNER BUILD. Bobbing The Runner!
Started by SR5Yota, October 13, 2008, 09:50:47 PM
GJToyotabug
rear bumper wont fit and sliders are probably beat up and welded on
SR5Yota
Quote from: NorCalToy on November 05, 2008, 09:58:47 PM
:thumbs: why couldnt you use your original sliders and rear bumper from teh truck?
They Both did not fit right. The rear mounts are alot different and the sliders were to long. I could have made the rear worked but did not want to work that hard on it. The sliders I could have cut down to size but did not want to.
I sold them on craigs list for what I payed for them.
Quote from: GJToyotabug on November 06, 2008, 06:24:01 AM
your right for the most part. sliders were fine just to long.
GJToyotabug
dang close but oh well still coudnt use them
SR5Yota
Can some one tell me what I all need to have duel case. cross memeber, duel shifter? foward shift tops shift. I dont know what I need.
toyotaboy
Quote from: SR5Yota on November 06, 2008, 11:57:09 AM
you should have a w-56 in your truck which means you need one more top shift t-case to use as a reduction box. you already have one in your truck. you need an adapter. obviously you will need to hold them up somehow so a homemade/bought crossmember will be needed. driveshaft work to lengthen/shorten them to fit. if your saying you want twin sticks. buy them, you have to take out a detent ball when you install them. everything is very simple
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
toyotaboy
the picture on page two of the tranny on the ground has a forward shift... if thats the tranny and t-case setup you have you need one top shift for the back case and use the one on the floor as a reduction box..... but the efi motor out of your truck should have had a w-56 and top shift behind it
you can also modify it like this instead of buying new shifter rails. http://pirate4x4.com/forum/showthread.php?t=689231&highlight=top+shift+conversion
rest in peace Effay
SR5Yota
The tranny in the pic thats the tranny that was in my truck last and is now in my runner. so its the wrong one?
SR5Yota
So what your saying is i need one foward shift and one top shift?
toyotaboy
no it will be fine.... i assumed you would have a w-56 from your truck since its an efi motor and the w-56 came with those motors stock. the tranny you have is from a carbed truck.
so you need :
a top shift case.... or a forward shift case and use the link above to convert it to a top shift. for your back case. you will use the one you have as your reduction box
an adapter
a crossmember
driveshaft work
cut a hole in the floor
rest in peace Effay
SR5Yota
Is there any problems with the carbed tranny?
GJToyotabug
usually a carb trany is a G52 or G54 they aer not as good as the W56 is most likely you have a W56a or b so it has a top shift T-case if you can find another top shift case from the same model you'll be good to go just get an adapter
toyotaboy
i dunno you tell me ... if its good its good... w-56 is stronger but i wouldnt worry about it
gttoyotabug. ist not a w-56 look at the pictures
rest in peace Effay
SR5Yota
It has a plug in on the tranny if that makes a difference? I had to plug into the wiring harness that goes with the motor. Do the carbed trucks have this?
GJToyotabug
SR5Yota
sorry im confused so that is a carbareded truck tranny that I have? :dunno:
Here is my other tranny I have sitting around what is it? :bowdown:
GJToyotabug
that looks to be a G series not sure exactly but looks to be a G
SR5Yota
Marlin does not sell the kit anymore to convert the forward shift to top shift . :(
GJToyotabug
nope but what you can do is but a top shift gear box and pull apart the rear half off and do it like that
SR5Yota
screw it im just going to build an exo first.
GJToyotabug
lol its not that hard i even know someone that has a top shift case for sale
SR5Yota
what goes first into the tranny with duels the top shift or the forward shift?
GJToyotabug
into the trany forward shift then adapter and then top shift
SR5Yota
toyotanner
hey man i have a top shift t-case if you need one it does need a seal kit but i'm local if you want to go that route
GJToyotabug
Quote from: SR5Yota on November 06, 2008, 08:29:24 PM
damn I have 2 broken studs on my nuckle...... grrr
EEEK!! more things to fix dont you just hate that
SR5Yota
what do you want for that t-case?
These trucks will nickle and dime you to death
SR5Yota
Have you seen the fifth stud setup for high steer from  bobby long. http://www.longfieldsuperaxles.com/
toyotanner
$40 just needs seals i have it in my truck now but i'm too lazy to do the seals haha so im just putting another case in
SR5Yota
