91 sas budget build
Started by yota88, October 13, 2008, 07:13:38 PM
yota88
i got a 91 std cab toyota pickup. i wanna do a marlin sas 4inch kit. what should i do for the rear to make it equal to the front with out having to buy the kit?
AaronB
not much, you can get blocks, chevys..........
yota88
yea i was thinking chevys but i wanna know what all you have to do to make 63inch chevys work
halfxspaid
Take some time and read up a bit.
http://www.pirate4x4.com/forum/showthread.php?s=&threadid=20665
I did this swap on my 85 and it wasnt that bad.  At the time I didnt know how to weld and got someone to weld up the spring perches for me with their 220, I suggest this for you if you dont weld.
Take a morning and go to your local junkyard and pull a set...cheap and easy.  You will have to relocate your hangers if you get aftermarket springs anyways...
Good luck!
85 longbed - Caged, locked, dual'd and armored
AaronB
AaronB
