2wd pumps and 4wd pumps are not the same, the 2wds have a smaller sector shaft, and a king spline that the 4wd does not have... 2wd pumps mount to the frame with 2 bolts instead of the 3 the 4wd pumps use.....also, if you get a power steering pump from a 22r, get it with the brackets, the pumps from pre 85 will not bolt up to a bracket from an 85+ 22r
jim are you a total moron? this is asking about PUMPS and you are telling him about BOXES. no where in his original post does he mention a box.
theres a "wishbone" shaped bracket that attaches to the bottom of the pump and goes down to a bolt on the front of the block just about mid ways of the alternator, i didnt use this wishbone for awhile and it tweaked my pump brackets , i guess the added leverage was too much for the upper brackets
You need to get me a pic of that glen Since I have a 76 celica head on mine I don't even have the boss on the front of the head for the idler pulley bolt. I made a half ass L bracket that went around to the bolt that holds the lift eye on the head, but had nothing going down so the whole assembly would kink down under hard throttle and loosen the hose. It wasn't too bad as long as I didn't tighten it too hard, but I'm in the process of making a bracket that'll bolt to the side of the head and tie in with the a/c compressor mount.
Started by burl4x4 Parts Wanted
Started by Makohon Parts For Sale
Started by KyYota Toyota Pickup/4Runner Tech 1979-95
Started by crazymoritz97 Toyota Pickup/4Runner Tech 1979-95
Started by 84_Stewart Axle/Differential/Steering
