Author Topic: hole in my frame !!!  (Read 1629 times)
toyofan7987
  • Male Posts: 124
  • Member since Jan '07
  • yoter boy till i die
« on: Sep 12, 2008, 10:04:19 AM »
ok so i found a rust hole in my frame right below were the front shackle goes ... so i was thinking of cutting it out and weldind in a solid plate, and then mounting my shackles below the frame. my question is were can i get a front shackle mount if anyweres or does anyone have a better idea ??
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
Re: hole in my frame !!!
« Reply #1 on: Sep 12, 2008, 10:06:32 AM »
I would not mount your shackle below the frame as that will mess up your pinion angle as well as your caster/camber.... just weld plates in and make new holes for shackle tubes would be the right way to do it...
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #2 on: Sep 12, 2008, 02:02:11 PM »
 :worthless:
toyofan7987 [OP]
  • Male Posts: 124
« Reply #3 on: Sep 12, 2008, 05:30:11 PM »
i dont know how to post pics ...???
Zack1978
  • Turtle Points: -3
  • Member since Mar '09
« Reply #4 on: Mar 26, 2009, 05:20:23 PM »
I have had a few frame repairs done on my trucks, and they never cut out the frame, they grind it down and clean it up, and weld heavy plates to the frame.
Zack
95yotakid
  • Turtle Points: 27
  • Member since Jan '09
« Reply #5 on: Mar 26, 2009, 08:32:12 PM »
defanately don't go below the frame it looks hella weak. My buddy bought a truck and that is how it is now  go threw the frame after plating much stronger
Last post May 31, 2007, 05:34:12 PM
by jimbo74
Last post Jan 23, 2014, 07:58:52 PM
by 69sixpackbee
Last post Feb 25, 2014, 08:26:04 AM
by Nation
Last post Jul 17, 2015, 12:36:36 PM
by TheeMikeB
Last post Aug 13, 2015, 01:13:19 PM
by 84Flatbed
