Author Topic: motor swap now it wont start  (Read 2743 times)
camo89
  • Male Posts: 308
  • Member since Apr '04
« on: Sep 07, 2008, 09:46:36 PM »
ok so i pulled the motor out of a 91 stick and instilled it in a 87 automatic.  timing is spot on. we have spark and fuel at the rail. so in the best of my knowlage it should run. it did sputter when i sprayed starting fluid in it.
i do not have the toqure converter hoked up if that makes a diffrance
mopar parts
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: motor swap now it wont start
« Reply #1 on: Sep 07, 2008, 09:49:39 PM »
which computer is being used? the 87 will want to see a nuetral start safety switch, that the stick doesnt have.....
camo89 [OP]
  • Male Posts: 308
« Reply #2 on: Sep 07, 2008, 10:03:31 PM »
the computer 4 the automatic truck wich is what the motor is in it turns over so the nutrail safty switch works
mopar parts
KDXSR5
  • Poser Shot Extraordinaire
  • Turtle Points: 61
  • Male Posts: 2,812
  • Member since Dec '06
« Reply #3 on: Sep 07, 2008, 10:07:38 PM »
could your dist possibly be 180 degrees off? Or did you not remove the dist when you swapped the engines?
camo89 [OP]
  • Male Posts: 308
« Reply #4 on: Sep 07, 2008, 10:09:45 PM »
timing is on i  pulled the valve couver to make shure valaves where closed with the rotor at 1
mopar parts
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #5 on: Sep 07, 2008, 10:11:48 PM »
Ok :thumbs: I am outta ideas then, lol
camo89 [OP]
  • Male Posts: 308
« Reply #6 on: Sep 07, 2008, 10:13:24 PM »
i am also
it dosent back fire
it turns over nicely no studder
mopar parts
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
« Reply #7 on: Sep 07, 2008, 10:21:23 PM »
The TPS p/n is different on the 91 engine & that might be the problem.  Put the 87 TPS back on & try it. It's worth a try. Also the injectors look the same put are different p/n's as well but those should work.
87 4Runner redo
camo89 [OP]
  • Male Posts: 308
« Reply #8 on: Sep 07, 2008, 10:23:56 PM »
all i swaped was a long block no eletrical from the 91 is in the 87 i used the orignal intake
only thing swaped block head valve cover oil pan
mopar parts
I.D.G.A.F
  • Male Posts: 306
  • Member since Dec '07
« Reply #9 on: Sep 08, 2008, 02:52:12 AM »
did you ground the block to the frame?
camo89 [OP]
  • Male Posts: 308
« Reply #10 on: Sep 08, 2008, 11:43:34 AM »
it is grounded from the block to the body in 2 places and from the frame to the block in one with the battery cable
mopar parts
camo89 [OP]
  • Male Posts: 308
« Reply #11 on: Sep 08, 2008, 05:30:48 PM »
so after playing with it more i have fuel to the intake and spark
if i spray starting fluid it will start so that leads me to fuel
dose aney one know if the injectors are suposed to have power all the tiem at bolth wiers
mopar parts
camo89 [OP]
  • Male Posts: 308
« Reply #12 on: Sep 08, 2008, 08:16:44 PM »
its alive sounds sick as a dog but its alive
mopar parts
KDXSR5
  • Turtle Points: 61
  • Male Posts: 2,812
« Reply #13 on: Sep 08, 2008, 10:02:22 PM »
So... what was it?
camo89 [OP]
  • Male Posts: 308
« Reply #14 on: Sep 09, 2008, 04:43:26 PM »
to be 100% honest i have no idea i went out turned the key and she fired up
its noisey im shure the valves need to be adjusted and what not but it runs
mopar parts
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
  • Member since Jul '05
« Reply #15 on: Sep 09, 2008, 06:01:32 PM »
Let's hope it doesn't have a bent valve.  I built one of my 22re's and  when I went to fire it up, the #4 exhaust valve bent.  I think it was something stuck in the valve guide from the machining process.  Then after I pulled the head, cleaned up the valve guide and replaced the valve, it didn't want to start.  Then I realized that the crank needs to be set at 5 degrees before you line the distributor rotor up to the #1 wire.
I.D.G.A.F
  • Male Posts: 306
« Reply #16 on: Sep 09, 2008, 07:09:22 PM »
There's something in the Hanes manual about crossing(jumping) two terminals somewhere in the engine bay so you can set the timing.  I would try that to get the engine on the same pace as the computer?
BUDDERS
  • Turtle Points: 15
  • Male Posts: 1,335
« Reply #17 on: Sep 10, 2008, 11:12:53 AM »
Yeah, you have to jump T1 to E1 on the DLC1 electrical connector under the hood.  This will drop the idle down to base idle so you can set the timing on the distributor.
Last post Jun 17, 2005, 06:18:21 PM
by Cheesemaker
Last post Mar 29, 2006, 05:06:41 PM
by toymech
Last post May 29, 2007, 12:35:55 PM
by GrenadedToy
Last post Jul 31, 2007, 09:55:17 PM
by kneedownnate
Last post Feb 20, 2012, 03:02:53 PM
by yotaneck13
