you can run that third in the front no problem, as long as the gears match. Look at the axle code on the VIN tag. it should say something like R150F/G102. the second set of letters/numbers is the gear ratio.or is the new third out and on the ground?
the V6 3rd member and my stock axle shafts front and rear will all bolt up together (A direct swap) with no problems or any other needed parts, right ?.
no, the front IFS axle is completely different and can't use a 8" diff
Started by GoaT General 4WD Discussion
Started by prang11 Toyota Pickup/4Runner Tech 1979-95
Started by blackdiamond Project Research and Build-Ups
Started by zebracrawler Axle/Differential/Steering
Started by Wainiha Newbie Questions
