1990 TOYOTA PU BUILT AXLES NORCAL
Started by vxrich, September 04, 2008, 02:21:50 PM
vxrich
Looking at buying a new project and wife said this needs to go first. 1990 Toyota 4x4 std cab pu 95% done. Located in Jamestown Ca 95327 New price 5000 Might do partial trade.
Specs list below
Front axle 529s,ARB,30 spline longs,TG cromo drive flanges,Six shooter knuckles and hysteer,ARP magnum steering studs,Sky mfg wide kit,Tg large diff armor,TG diff breather,TG U-bolt flip kit,TG gussett kit,Fresh rebuild all new seals and bearings.
Rear axle 529s,spool,Cromo axle shafts,Sky Mfg disk brake kit with all braided steel lines,TG diff breather,TG U-bolt flip,TG small diff armor,1.5 inch spacers and new wheel studs,Fresh rebuild all new seals and bearings.
Front suspension Sky Mfg front hanger set 3\4" forward,Sky Mfg boomarange shackles, TG 3" springs,Doschtec shocks
Rear suspension TG hanger relocation kit,TG 4" springs,TG 5" shackles,Sky Mfg shock mount(puts shocks /\),Bilstien 5100 shocks
3.0 V6 motor (unknown milage) K&N intake,NWOR stainless steel headers
Inchworm gear driven Tcase adaptor and 5.0 gears(single case)TG crossmember
Front driveline is a Tom woods long slip. Rear is stock.
Cab is rinolined red has some dents and dings,TG front bumper,TG sliders with gussett kit.
Bed is from a 2wd and is in the middle of 12" bob and 14"dovetail
(comes with two tailgates not modified for dovetail yet. One is rinolined)
The bad
Truck is Salvage title (cab has been replaced)
Will not pass smog in current condition (no cat)
Trans sometimes pops out of first (comes with another tranny)
Bed not finished needs welding and to be rinolined
Needs ARB compressor and switches
Tires are 35\12.50\15 Pro comp muds 2 at 50% 2 need to be replaced
I don't know how to post pics here but I have some on Pirate
http://www.pirate4x4.com/forum/showthread.php?t=722617
vxrich
vxrich
vxrich
Must sell 5000 you deal with smog.....
