Author Topic: Front diff drain plug???  (Read 4764 times)
yota pu/runner
  • Male Posts: 208
  • Member since Apr '08
« on: Sep 03, 2008, 08:39:34 AM »
So I went wheeling two weeks ago and just happened to rip the drain plug out of my front axle :smack:.   I have an 80 pu and what I'm looking for is if someone knows the size or knows where I can get a tap and die to re-thread it or if someone knows another good way to repair it.  I would like to keep it on the less expensive side preferrably.
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
  • Member since Sep '07
Re: Front diff drain plug???
« Reply #1 on: Sep 03, 2008, 08:54:32 AM »
http://www.marlincrawler.com/htm/diff/pickup_diff.htm    or you could weld it up and never have to deal with it again.
yota pu/runner [OP]
  • Male Posts: 208
« Reply #2 on: Sep 03, 2008, 09:04:34 AM »
Sweet that is exactly what i'm looking for.  But if you weld it up how exactly are you going to be able to drain your fluid without pulling the whole thing apart.
ninja turtle
  • Turtle Points: 38
  • Male Posts: 1,072
« Reply #3 on: Sep 03, 2008, 09:49:36 AM »
you arnt.
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #4 on: Sep 03, 2008, 09:52:14 AM »
I thought that was a great idea too until i ripped it out (the low profile plug) on the trail too......  :ack:
best bet is to shave the hole and weld it up (or just weld it up)....to drain the fluid just remove one of the two bottom studs on the diff
Quote
yota pu/runner [OP]
  • Male Posts: 208
« Reply #5 on: Sep 03, 2008, 09:59:26 AM »
That is good to know before I go and buy myself some new drain plugs and end up spending money when I don't have to spend any money at all.  Thank you for the info.  It will be put to use.
DAWGTOY
  • Turtle Points: 460
  • Male Posts: 212
  • Member since Jul '04
  • aint too old & broke up to sit down yet
« Reply #6 on: Sep 03, 2008, 11:41:37 AM »
i too have knocked out drain plugs, both front and rear.
what i've been doing lately is after the plug is installed
i put a small spot weld to keep it from turning.
then when i change my oil (frenquently) i grind off the
spot weld change and repete.
 dawg
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #7 on: Sep 03, 2008, 11:58:25 AM »
Weld it closed, remove the studs on the bottom 3 of the 3rd and put bolts in place of the studs. I would weld the bolt in place like DAWGTOY mentions that way if you have to open it up that way you can. Plus the magnet is still there to catch the metal slivers.
yota pu/runner [OP]
  • Male Posts: 208
« Reply #8 on: Sep 03, 2008, 12:50:26 PM »
Thanks for the info my plan now is to weld it in place.  Rocksurfer you said replace the studs with bolts.  Do they need to be tapped or are they already threded?
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
« Reply #9 on: Sep 03, 2008, 12:53:36 PM »
already threaded
yota pu/runner [OP]
  • Male Posts: 208
« Reply #10 on: Sep 03, 2008, 01:24:58 PM »
perfect that will make it easier.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #11 on: Sep 03, 2008, 04:27:01 PM »
they have to be metric bolts though since they are a metric thread.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #12 on: Sep 04, 2008, 10:42:48 AM »
Pull the bottom 2 bolts out to drain the diff
Quote
yota pu/runner [OP]
  • Male Posts: 208
« Reply #13 on: Sep 04, 2008, 10:50:36 AM »
The pics help a ton, I'm hoping to get it done this weekend but we'll see.  More important I need to get my new power steering box bolted up first.
Volcom
  • Turtle Points: 269
  • Male Posts: 2,418
  • Member since Sep '04
  • Colorado Rocks!
    • http://www.rockfrogs.org
« Reply #14 on: Sep 04, 2008, 12:29:02 PM »
I cut the entire drain plug out of the F&R axles when I was building my crawler.  I ended up welding 3/16" plate in place inside and out and grinding the outside smooth.  Works out very well on the rocks.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #15 on: Sep 04, 2008, 08:17:39 PM »
I ground down the outside. Chamfered the hole on the outside. Screwed the plug in from the inside and tacked it in a couple of places. Grounded it down where it was standing proud on the outside. Welded it up and ground the welded down. I JB welded a small magnet on the inside of the housing at the bottom away from the ring gear.
Since I installed 5/16 (could be 3/8 I do no remember which I used) bolts from the inside out to hold the third in place I just undo the third and and push up to let it drain. I also run copper washers on the bottom two to help stop it from leaking. I was having a problem with the lube following the threads on the bottom two bolts and having a slight drip. The copper washers and ny-lock nuts stopped it.
The reason I did the bolts from the inside was some guys have been pulling the diff. studs out of the housings on really tough sections.
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #16 on: Sep 05, 2008, 07:38:39 AM »
Good idea about the JB'ing the magnet on the inside of the housing.  I'll have to do the same next time I have the third out.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #17 on: Sep 06, 2008, 07:30:24 AM »
I used bolts going from the outside in....seems to me that if there is anything sticking out (anything at all, like a stud, nut or bolt) it is gonna get bent or broke and will LEAK.....
only problem i can see with this is that the allen bolt could get rounded off...but so could anything else
Quote
OOPS
  • Male Posts: 2,561
« Reply #18 on: Sep 06, 2008, 08:34:31 PM »
After seeing 3-4 rear ends pulled out of the housings I decided to drill and tap the holes bigger. Then I ran the grade 8 bolts from the inside out.
Redeyejedi
  • Male Posts: 115
  • Member since Jan '07
« Reply #19 on: Sep 08, 2008, 01:16:13 PM »
volcom, do you have any pics of your axle with the plates?
alcohol.....the cause of, and solution to, all life's problems
http://www.flickr.com/photos/78234902@N06/
Volcom
  • Male Posts: 2,418
  • Colorado Rocks!
« Reply #20 on: Sep 08, 2008, 01:42:35 PM »
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
yota pu/runner [OP]
  • Male Posts: 208
« Reply #21 on: Sep 08, 2008, 02:42:09 PM »
wow that sure does look nice, I'm pretty sure I'm just gonna weld the plug on and call it :boobs:.
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
« Reply #22 on: Sep 09, 2008, 06:18:26 AM »
smart thinking...looks like i might be doing this in the future......i got a giant puddle of gear oil on my gayrage floor right now
Quote
havik
  • Turtle Points: 220
  • Male Posts: 737
  • Member since Dec '05
« Reply #23 on: Sep 13, 2008, 05:25:27 PM »
maybe i am slow but how do you drain the diff if the bolts are from the inside out?
i like the idea of going with bigger grade 8 hardware.
got another 85 runner. build coming soon!!
  • Male Posts: 8,707
« Reply #24 on: Sep 13, 2008, 05:36:38 PM »
when you crack the bolts loose, all the fluid will pour out the bottom, the third isnt stuck anymore
havik
  • Male Posts: 737
« Reply #25 on: Sep 14, 2008, 08:07:17 AM »
got it now
thanks Jimbo
Last post Jul 06, 2004, 02:23:29 PM
by superstarai
Last post May 04, 2007, 09:48:07 AM
by All_Set
Last post Jul 09, 2007, 10:39:38 PM
by jimbo74
Last post Jan 10, 2009, 05:14:34 AM
by DTB
Last post Aug 08, 2020, 02:00:46 AM
by Gnarly4X
