will an A340H from a 93 go into an 88 with no mods
Started by Ozy, August 09, 2004, 04:56:22 PM
Ozy
Marlin
If both of the autos are from a V6, then only the wiring harness that goes to the solenids in the transmission oil pan, and the netural saftey switches will need to be changed. I belive the 89 and newer units use an updated plug design.
If one of the trans are from a 4 cyl, then the torque converter will have to be removed and the bellhousing exchanged.
Both transmissions should be the same length.
Marlin
