Need some info for a lift
Started by jrock, August 18, 2008, 06:25:15 PM
jrock
I am gathering crap for a lift, if you can call it that. I'm looking for as little "lift" as possible, I only want to fit 33's but I want a good amount of flex. This is my DD and I often load the bed with junk, often max it out (IE. 1000lbs).  So hears what I've got:
I am using F150 rears in back, reversed, and either TG4" or my rears in front. I have two Rancho 12" and two Rancho 14". I plan to put on front hanger and banana shackles for the front, one day I will add hi-steer. If you need more info just ask. :thumbs:
Will the 14's fit in the rear with as little as 3" lift? Or should I get 12"?
Will the 12's fit in the front?
What will I have to do to correct the pinion angles?
bigarms23
on my set up i have the 14s in front and 12s in the back thats with marlins 4inch leaf springs
jrock
Quote from: bigarms23 on August 18, 2008, 06:47:57 PM
14s in front with marlins 4inch leaf springs
What did you do to make those fit?
