Author Topic: shifter boots  (Read 3653 times)
THE ROCK
  • Male Posts: 219
  • Member since Apr '07
shifter boots
« on: Aug 13, 2008, 08:27:19 PM »
 :usa: what a pain :moon: when doing dual t-cases...the rubber boots caused my shifters to jump out of gear at the worse times due to tension on the levers..I picked up a S-10 "pleather" cover for the trans, honda civic boot for the t-cases-problem solved, cab 90% cooler & quieter.  :blah: no longer have to look at the ground,or smell that exhaust smell. :eyebrow: hope this works for someone. be sure to get the metal mt. plates  :beerchug: cost for all was less than 20$ from picknpull :usa:
« Last Edit: Aug 14, 2008, 09:15:45 AM by 79coyotefrg »
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
Re: shifter boots
« Reply #1 on: Aug 13, 2008, 11:20:57 PM »
Got some pic's?
87 4Runner redo
THE ROCK [OP]
  • Male Posts: 219
Re: shifter boots
« Reply #2 on: Aug 14, 2008, 06:24:26 AM »
 :hammerhead: i dont know how to upload pics :hammerhead: sorry
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
Re: shifter boots
« Reply #3 on: Aug 14, 2008, 08:01:20 AM »
Could have just used the Marlin HD shift spring $4.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: shifter boots
« Reply #4 on: Aug 14, 2008, 08:40:50 AM »
True that would have held it in gear but it still doesn't eliminate the true problem which is the pressure being applied to the shifter which could cause problems down the road. Better to fix the problem than to mask it with a band aid.
Did I just say that? :rofl:
*ROKTOY*
  • Male Posts: 1,066
Re: shifter boots
« Reply #5 on: Aug 14, 2008, 06:16:16 PM »
The spring is the problem.
  • Momentum Man
  • Lego Enforcement
Re: shifter boots
« Reply #6 on: Aug 14, 2008, 06:37:49 PM »
I understand that a stronger spring will hold it in but the boot should not be able to pull the shifter out of gear even with an old spring.
THE ROCK [OP]
  • Male Posts: 219
Re: shifter boots
« Reply #7 on: Aug 14, 2008, 08:40:13 PM »
 :usa:that was my problem..an example would be driving in 2nd gear w/ reduction box in low...those rubber boots were always pulling on the shifters....rip the rubbers out, problem solved, carbon monoxide in cabin from rigs ahead of mine
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: shifter boots
« Reply #8 on: Aug 14, 2008, 08:59:27 PM »
can you run a hd shift sping in a stock single case? i have never had my case get knocked out of gear... ubt what could it hurt to run it?
*ROKTOY*
  • Male Posts: 1,066
Re: shifter boots
« Reply #9 on: Aug 15, 2008, 06:33:09 AM »
That is why the spring is shot, the rubber boot should not cause it to pop out of gear with a good spring even a stock one.  The spring no longer has enough tension to keep the detent ball in the shift rod notch, and the slightest pressure will make it come out of gear. Even if you find that with the boot removed it does not pop out of gear, eventually it will start to pop out again. The correct fix is a new spring stock or HD.
« Last Edit: Aug 15, 2008, 06:40:10 AM by *ROKTOY* »
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
  • Member since May '04
  • From Reykjavik Iceland...
    • R&T
Re: shifter boots
« Reply #10 on: Aug 15, 2008, 02:22:27 PM »
x2
 2,4 dti duals 2,28 x 2,28 to 8" 5.71 with arbīs  and 39,5" trxus
Tallchevy
  • Male Posts: 3,562
Re: shifter boots
« Reply #11 on: Aug 15, 2008, 04:04:08 PM »
I didn't know your old 2wd truck had a t-case  :headscratch::smack: that would explain why it never popped out!
Have you taken your 4x4 out yet?
87 4Runner redo
  • Momentum Man
  • Lego Enforcement
Re: shifter boots
« Reply #12 on: Aug 15, 2008, 08:20:09 PM »
:rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2:
CrazyYota
  • Turtle Points: 92
  • Male Posts: 1,073
  • Member since Oct '05
Re: shifter boots
« Reply #13 on: Aug 16, 2008, 07:25:06 PM »
X2 i had the same problem before i installed Mc gears in my tcase it would pop out of low when the clutch was applied, one of the sprigs was broken.
THE ROCK [OP]
  • Male Posts: 219
Re: shifter boots
« Reply #14 on: Aug 16, 2008, 11:11:20 PM »
 :yesnod: did the hell hole trail, no problem...it was those damn rubbers!when the truck flexes,  the entire drivetrain moves just enough while the boots remain fixed to the body-  to pull the shifters out of gear! the pleather boots cover the shifters w/o tugging on the levers
THE ROCK [OP]
  • Male Posts: 219
Re: shifter boots
« Reply #15 on: Aug 16, 2008, 11:14:03 PM »
 :clap2: just for giggles, I will replace the springs the next time the trans is removed..assumig it has to be removed to install the spring{s}
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
Re: shifter boots
« Reply #16 on: Aug 16, 2008, 11:27:01 PM »
There's 3 plugs on the center plate.   The spring and a ball are behind the plug.
You should be able to get to them without removing the trans.   (unless the allen key on the plug has rounded out)
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Last post Dec 13, 2008, 05:07:24 PM
by third coast cruisers
Last post Apr 08, 2010, 08:06:01 PM
by nsmick16
Last post Mar 30, 2016, 02:21:54 PM
by OTO Phil
Last post Jan 31, 2017, 02:36:19 PM
by Erick561
Last post Mar 28, 2023, 04:15:23 PM
by SolidAxle
